[C2] Brake calliper
Old Sep 9, 2021 | 10:20 AM
Rebellen's Avatar
Rebellen
Default Brake calliper
Hallo out there.
I have a leaking rear brake calliper. The problem is that the mounting bolts are stuck. I’ve used a 50cm bar and struggeld hard but couldn’t loose them. A little to close to the petroltank to use propan to heat.
An idea come up. Is it possible to restore it if I split it in place and remove the disk?
Old Sep 9, 2021 | 10:56 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
As long as you do not have fumes, heating the bolts is ok with a small hand held torch. First, try using a penetrant, let it sit a day or two. Then hit it several times with a hammer. The liquid and the hammering should break it loose. Dennis
Old Sep 9, 2021 | 11:10 AM
Tampa Jerry's Avatar
Tampa Jerry
Have you applied Liquid Wrench or Bead Blaster to the bolt and threads for a few days? I have always had success by using an impact wrench with a six point socket. Sometimes tightening the bolt a fraction can break a rust bond. The bolts should be able to take the punishment as they should be grade 8. You could also try putting an extension pipe on the breaker bar. Jerry
To Brake calliper
