Trans plug
Old Sep 29, 2021 | 11:38 AM
prestige6's Avatar
prestige6
Default Trans plug
I'm trying to get the trans fill plug out on my trans. Can't do it with a 9/16 wrench. What size special socket do I need so I don't strip this?? I ordered a 8 point socket and also what Dads 67 427 suggested.
Old Sep 29, 2021 | 11:57 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
They do make square size socket
Old Sep 29, 2021 | 12:00 PM
prestige6's Avatar
prestige6
I can't find it anywhere online.
Old Sep 29, 2021 | 12:13 PM
Nowhere Man
Amazon Amazon
Old Sep 29, 2021 | 12:15 PM
Dad's '66 427's Avatar
Dad's '66 427
2020 C2 of the Year Finalist - Unmodified
Would this work?
Amazon Amazon
Old Sep 29, 2021 | 09:09 PM
DSR's Avatar
DSR
I use a adjustable spanner wrench.
Old Sep 29, 2021 | 09:46 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I use a 12 point socket (19mm) dif and an 8 point socket (9/16") on my transmission....Man, I hope that's correct! I don't use them very often!!!
Old Sep 30, 2021 | 02:57 PM
prestige6's Avatar
prestige6
Originally Posted by Dad's '66 427
Worked perfect..
Old Feb 7, 2024 | 06:29 PM
solar88's Avatar
solar88
SUCCESS ! ! I used my new 4 point pipe plug socket with a 1/2” breaker bar and finally got to hear that sweet snap sound where you know it came loose and didn’t break.
Old Feb 8, 2024 | 10:26 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Glad it worked out. For anyone else reading this, I had very good success getting my stuck plug removed pretty easily after applying heat from a propane torch around the plug. Try to keep the heat off the plug and play the flame on the aluminum housing immediately surrounding the plug. I don't recall how long, but think it wasn't more than a minute of heat and it broke loose without grunting.
Old Feb 9, 2024 | 06:01 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Many years ago, I bought a set of 8-point sockets. They work great as long as the corners of the plug haven't been rounded off.
Old Feb 14, 2024 | 09:54 AM
6D2148's Avatar
6D2148
I had one of these in my pile of old tools that I never use, not even sure where or when I got it. It works perfect on any size square plug or nut, won't round corners or slip, works even if corners are rounded. Has no teeth to dig or damage. Still available, check this out.
Chip
To Trans plug
