1959 Ignition Switch Problem
Old Oct 20, 2021 | 06:11 PM
Jones.gf's Avatar
Jones.gf
Cruising
Default 1959 Ignition Switch Problem
Have 1959 Corvette, slightly modified with front discs, Edelbrock Electronic Fuel Injection, and alternator. Consequently due to the Edelbrock electronic ignition system, the tach has been replaced. The problem is with the ignition switch, When turning the switch to the off position, the starter tries to engage. Turning it very slowly eliminates the issue but is NOT how it's done normally. Ordered and installed 3 different replacement switches from different sources, all had the same result. Has anyone had this problem and resolved it.
Old Oct 20, 2021 | 07:20 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
I'll state the obvious - the problem apparently is not in the switch(s). Something is either wired wrong, or maybe touching something else where it shouldn't be. Realizing the wiring has been modified to some extent, but do you have wiring diagrams for how it originally was? That's going to be a help at some point.
Old Oct 21, 2021 | 12:06 AM
John S 1961's Avatar
John S 1961
Pull the switch from the dash. Hook it up dangling. Does it display the same behavour? Drive around some. It is shorting on the guage console. Or not. Then install correctly.
Old Oct 21, 2021 | 10:19 AM
Jones.gf's Avatar
Jones.gf
Cruising
Thanks for your reply... The mechanic that did the switch installation 3 different times verified that the wiring was correct. No, I don't have a clear wiring diagram of how it originally was.
Old Oct 21, 2021 | 10:56 AM
65GGvert's Avatar
65GGvert
I believe that something is being missed in the description of the issue. What else happens? Do the gauges shut off when you move to off? Does the starter engage properly when turned fully to start and disengage properly when the key is released? Physically and electrically, turning the key off quickly should make no difference in turning it off slowly. Are you sure you're using the correct switch and not one with an accessory position that is wired to the solenoid? The 59 switch has no acc position, and should go from "on" to "off" in one click. There should be no continuity to solenoid anywhere between "on" and "off". Is it possible that the timing or some other issue is causing the car to continue to try to run when ignition is off instead of the starter trying to engage as you describe.
The whole scenario doesn't make electrical sense with the correct ignition switch.
Old Oct 21, 2021 | 11:48 AM
Jones.gf's Avatar
Jones.gf
Cruising
I ordered two 1959 Corvette switches from two different supply houses along with the one already in the car and they all respond the same with no accessory position. The car run well to 4,000 rpm It starts easily with no problem and no throttle and the starter disengages properly. There seems to be no timing issue. When turning to the off position normally, the engine doesn't continue to run but shuts down and the starter tries to engage. The gauges shut off in the off position. The switch has the positions lock, off, on, and start. The mechanic believes an original switch manufactured by GM would solve the problem instead of the manufactured replicas of today. Since I'm no mechanic, I can't argue the point and that's why I looking for some insight and I appreciate yours.
Old Oct 21, 2021 | 12:14 PM
Railroadman
I suppose all 3 switches could have come from the same Chinese factory......
Old Oct 21, 2021 | 01:31 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Going the other way, from LOCK to OFF, does the starter try to run in the OFF position?
Old Oct 21, 2021 | 02:26 PM
Jones.gf's Avatar
Jones.gf
Cruising
No...I just to my brother who had a friend with the same problem. He solved it by acquiring a used GM switch. So, right now I'm going to try to buy a GM manufactured unit. If you know where I could get one, please let me know. Thanks...
Old Oct 21, 2021 | 04:16 PM
jim lockwood
Wait.... what? So going from ON to OFF engages the starter but going from LOCK to OFF does not????? Is that what you are observing?????
Old Oct 22, 2021 | 10:14 AM
Jones.gf's Avatar
Jones.gf
Cruising
Correct... Going from LOCK to OFF does NOT cause the starter to engage but going from ON to OFF when the engine is running does engages the starter.
Old Oct 22, 2021 | 10:44 AM
65GGvert's Avatar
65GGvert
Pull one end of the coil wire out, turn the key to start and briefly engage starter and then release to run. Now turn key off, does starter engage? If so, something is wonky with your ignition switch. If not, the switch is not the problem and you have an issue with the starter or solenoid.
Old Oct 22, 2021 | 10:56 AM
jim lockwood
OK, new question..... does the starter engage when you go from ON to OFF with the engine NOT running?
Old Oct 22, 2021 | 12:53 PM
65GGvert's Avatar
65GGvert
Sounds familiar.
Old Oct 22, 2021 | 01:09 PM
Jones.gf's Avatar
Jones.gf
Cruising
As I mention the engine has an Edelbrock Electronic Fuel Injection system with electronic ignition. Thus, it appears to have a coil for each cylinder. Since I'm not familiar enough with this, there doesn't seem to be an easy way to disconnect the coils. Thus, leaving everything connected, I did turn the key to start and briefly engage the starter without starting and released to run. I turned the key off and the started did NOT engage.
Old Oct 22, 2021 | 01:10 PM
Jones.gf's Avatar
Jones.gf
Cruising
No, it does NOT engage when the engine is NOT running.
Old Oct 22, 2021 | 03:18 PM
jim lockwood
That is very useful information.
My hunch is that your starter is getting momentary energy from the generator as the engine is spinning down.
Take a look at the connections attached to the "B" terminal of the generator (or the related terminal on the Voltage regulator). Are there extra wires? If so, to what do they connect? With the engine off, is there any continuity between the generator "B" terminal and the starter "S" terminal? There should not be, but is there?
Old Oct 22, 2021 | 05:16 PM
Jones.gf's Avatar
Jones.gf
Cruising
Thanks, I'll have to my mechanic take a look at it since the generator has been replaced with an alternator.
To 1959 Ignition Switch Problem
