1966 L72 Spark Plug Question
Old Nov 15, 2021 | 06:52 PM
TeeMac88's Avatar
TeeMac88
Default 1966 L72 Spark Plug Question
Hi. If I use an AC 43,44 or 45 XLS plug should I be concerned about the extended tip on them not having enough clearance? Or should I just go with an XL? Thank you, Tom.
Old Nov 15, 2021 | 09:02 PM
Avispa's Avatar
Avispa
The XLS extended tip plugs will work perfectly.
Old Nov 16, 2021 | 06:46 AM
TeeMac88's Avatar
TeeMac88
Thank you. I will go with that...
Old Nov 16, 2021 | 01:10 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'd offer that you should make sure that your installed heads are what an L72 came with. If they were changed out to something different then extended tip may cause clearance issues. If changed it could also affect whether you install tapered seat or gasketed seat plugs.
Old Nov 16, 2021 | 02:31 PM
TeeMac88's Avatar
TeeMac88
Thanks 67:72. I have stock heads and I have seen some posts about guys that were concerned about using the extended tips, so it started me thinking... So I guess I can use either the xls's or the xl's. Thanks again.. Tom.
Old Nov 16, 2021 | 08:26 PM
Factoid's Avatar
Factoid
Good info, thanks for asking!
To 1966 L72 Spark Plug Question
