[C1] '61 Harmonic Balancer Install
I went into Amazon and found where I purchased that tap, took all of 30 seconds.
The Tap shows the required drill bit right on the Tap you can read it in the add. 27/64. I bought a new drill bit just because I wanted a very fast clean cut. I did not have to use that much pressure, it cut really well.
The crank is surface hardened but the center is not that hard.
This is is how I do them easy if you happen to have a lathe laying around.
https://www.corvetteforum.com/forums...tall-64-a.html
As for the process, I always use a thin 1/8" thick ribbon of RTV all the way around the crank snout (towards the front end of the snout, just in front and over the key), instead of the light coating of oil.
The RTV does a couple of things, including adding some lubricity to pulling on the balancer, while it is still semi-liquid.
But when it hardens, it also seals the path that any oil could migrate down the keyway.
It also (somewhat) prevents the balancer from loosening.
However, it is still easy to pull the balancer back off, using the correct tool.
Note that when reinstalling the balancer that is retained by a bolt, do not use the bolt to reinstall it!
If a bolt is used, it is very possible to pull the threads out of the crank.
Always use an install tool that is threaded all the way to the bottom of the crank threads, and then a larger washer & nut is used to pull the balancer on.
Once it is fully seated, loosen the nut, remove the threaded install tool, and install the large washer & bolt.
Plasticman
I make sure my extended bolt is at least 1/2" threaded down into the crank before it starts pressing the HB on. When this bottoms out I switch to a shorter Bolt, maybe 1/2" shorter than the long bolt. Press the HB on a little further then finish with the actual OEM bolt.
I have a selection of bolts and washers handy so that is how I do it but a proper tool would be easier and faster.
