[C1] 60 headlight switch removal
Old Dec 11, 2021 | 03:38 PM
Rusty60's Avatar
Rusty60
Default 60 headlight switch removal
I have the headlight switch out and bout an aftermarket one that tough to get the **** in and out with out major screwing around with it.
my real question is for tightening the lock but I ordered this tool from zip and the whole nut goes right inside the tool
assuming they send the wrong one?
Old Dec 11, 2021 | 04:49 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
A pair of needle nose pliers works fine!
Old Dec 11, 2021 | 04:59 PM
Pilot Dan's Avatar
Pilot Dan
Start the nut back on the switch by hand so you don't cross thread it, then I use a large wide flat blade screwdriver to tighten it down. Never needed that tool.
Old Dec 11, 2021 | 05:02 PM
Rusty60's Avatar
Rusty60
I ended up using a large flat head screw driver
thanks for the reply guys
claf's Avatar
claf
I found the threads on the aftermarket switches are not "user friendly" and require a lot of finesse to get the nut attached. Patience is your friend. I'll agree to the use of needle nose pliers to tighten AFTER you have it finger tight.
Old Dec 11, 2021 | 05:12 PM
Rusty60's Avatar
Rusty60
I had no problem starting it but between the aftermarket switch and after market ****
they won’t click together, the button seems pretty much useless
i actually disassembled it and can get it locked in while off the dash
once installed it’s not going in
i stopped for the night before I scratch my newly painted dash
Old Dec 11, 2021 | 05:44 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
I found that out with the ignition switch.
Old Dec 12, 2021 | 08:03 AM
petdoc's Avatar
petdoc
Man, I totally get that! It's so frustrating with the poor quality seen in so many replacement parts today. That instrument panel is absolutely gorgeous tho! Gonna look great once installed!
-Lee
Old Dec 19, 2021 | 06:24 PM
Rusty60's Avatar
Rusty60
To update this the aftermarket **** was going in I could hear a click but was not engaging
as so as I pull it out it’s not hooked in
i took a small file and filed the end of the rod that slips the the little bracket in the headlight switch
did not take a lot but it finally clicked in and should work
although the button does not seem to release it at the moment lol
thamks for the earlier help
russ
To 60 headlight switch removal
