[C1] Pilot bushing
the inner dimension is correct,
What’s the easiest way to track down the correct bushing
measure the outer and inner dimension and I should be able to find one?
I dint have it in front of me, I should have measured before I left the shop
Larry
EDIT: I found and attached it for you.
. http://www.autogear.net/wp-content/u...hing_chart.pdf
i thought it would be a small needle bearing but is this my pilot bushing
( blue arrow)
does nothing go in the yellow marked spot
i was looking for a bushing to fit that
I have used the pilot bearing with rollers ONE TIME!!!!!!!!!!!! NEVER again!!!! When those needles go bad, and crumble into small pieces (I have seen it happen to several bearings), here is what happens to the pilot on the end of the transmission input shaft.
The brass plug (being softer) will not splinter.
I also always wear safety glasses.
But if the pilot bushing needs that much "hammering", then something is not correct, and a few minutes measuring, then some lathe time should fix that issue.
Plasticman
The pilot bushing to crank interference fit is about 2-3 thousandths of an inch. So put the bushing in the freezer overnight to shrink it down a bit and then use a normal hammer. A BFH is not needed or desired. If that is what it takes, then the pilot bushing ID will likely be distorted and too small a hole for the input shaft. It should have a few thousandths of an inch clearance to the input shaft.
Larry
Russ, I hope you have a happy new year, I have been kind of following your progress on your 60, and if I can help you in any way let me know.
I turned 79 last month and still drive my 60 about every day, since it was in the 80s I put a few miles on it today.
Bill
Didnt know you could order them different sizes that is a plus. Learned the hard way about using regular old auto parts store bushings. Trans came right back out lol. Summit still sells them I believe.
Shoulda checked to see if it slipped over the input shaft ok prior to installing those are no fun to get out.
From reading many posts about these pilot bushings it seems like there is a huge disparity in crankshaft hole diameter sizes, maybe it was the tooling used, my memory pictures a drill bit looking hole so if that's the case the bit may wear. Don't know if this is really the case, I only know what I had to do with mine.
But then you do what you have to do......................
Larry
Notice that the instructions state that you should “press the bearing into the crankshaft using an arbor press and DO NOT use a hammer”. Well, I don’t have an arbor press and I don’t know how one could be mounted to press the bearing into the crankshaft, so I made a tool that mounts in the flywheel holes and presses the bearing into the crankshaft. I think my bearing/crankshaft interference fit was about 0.002”.
My Grandpa was a machinist
He often made one off tools.
Thanks for sharing
Marshal
I ordered a new two prong puller from Summit but it had the same problem. As you can see in the pictures below, the hole on back side of the bearing is tapered and the steps on the ends of the prongs are only 2mm wide, not wide enough to reach the flat part of the bearing. So when I tried to pull the bearing, the prongs flexed enough so they could not grip the bearing enough to pull it out. I did manage to pull a few of the bearings out of the race.
So I tired the three prong puller and it felt like it was working, except, as you can see in the picture, the horizontal bar was bending. So the next step was to replace the horizontal bar with something more substantial. In my case I used a piece of 1”X 1.25” bar stock which did not flex, and finally the bearing was removed.
I bought a large tap, The bushing is soft so the tap cuts threads into the bushing easily.
Then I use a bolt the same thread pitch and size.
I thread it into the bushing, let it bottom out in the crankshaft hole and it pulls the bushing right out.
Easy and very effective.
