65 TI conversion
Worked great for about 8 years, then began starting hard. After much diagnosis, discovered no spark while cranking. Solution was to disconnect the 12v from the starter. Then I had spark while cranking. (I know, it makes no sense, however when connected, no spark while cranking)
Worked great last year, however, began to start hard again this past Summer and also ignition breakdown above 4k. When pulling a plug wire, the spark was very weak.
For trouble shooting, I connected a HEI 4 pin module in place of the TI amp. (TI distributor triggers the HEI Module) I now had a Huge spark and could easily do 6k with no breakdown. Starting was amazing. Starts on the first turn.
I had some concerns about leaving this setup, as to the life of the HEI module connected to the TI coil, or the life of the TI coil itself.
In looking thru "acquired" stuff from over the years, I found a HEI remote coil (E-core type - vintage 1995 Camaro) and connected that in place of the TI coil. That worked great as well.
With everything zip tied under the hood, I drove it for a week or so that way. I was so impressed with the starting and running, I mounted the HEI coil on the TI coil mount holes, and mounted the HEI module hidden under the brake booster.
I've been using this setup since July, works very well. As Fox mentioned, I was also TI "tired" and just wanted something that worked.
I may repair the TI sometime, however plan to enjoy how great the HEI setup works. All TI harness and amp are still in place. (Not used)
Below is a diagram on the setup, very easy setup. Note, HEI module does require a heat sink, they can get hot. Also used existing TI ignition power wire to energize a relay, to connect 12V to the HEI module, as it requires more power. (12 Gauge wire)
Cost was "0" dollars, module & coil left over from other projects.
Otherwise, the amplifier or the connections to it might be a problem?
Hope it's something simple and you are back on the road!
Gerry
Question for you. I have never seen an HEI module out of a distributor, do you think it will fit inside the TI amp? I've been thinking about this method for my L72 with missing TI also. Thanks
Steve
I did experiment with the module in a TI amp many years ago, however never actually used it any more than testing, however it did work. I mainly carried it as a spare. I see no reason you could not use it in place of the TI amp.
Some wiring would need to be changed, as I believe the existing 12+ wire to the TI amp is a resistance wire. The HEI module needs a good high current 12v supply. (12 gauge wire from a good source) I'm using a relay and picking up the 12v from the horn relay.
Below is a photo of the module mounted.
Barry
Barry
Steve
Barry, on the drawing you posted I do not understand the ground with a ring terminal showing it goes on top of the module? And there's a condenser in the TI box?? Thanks!
Steve
Steve
As for the condenser in the TI box, I have no idea why I used that. That particular setup never went "into production". Just carried it for a backup which never got used.
Note, for the "B" & "C" electrical connection on the module, I used an alternator (internal regulator) pigtail, same spacing.
