67 running boards
Old Jan 13, 2022 | 05:55 PM
quahog's Avatar
quahog
Default 67 running boards
I'm in the process of reassembling my 67 and was trying to attach the running boards. There is no way I can clip the boards over the mounting strip there just does't seem to be eneough room to attach the board . I stepped the mounting strip out with washers and there still a no go situation . Am I missing something the car is straight and the parts are nos / any help would be appreciated. Thanks in advance. Jeff
Old Jan 13, 2022 | 06:07 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Some of the last cars to have running boards where made before WWII. Your car has rocker panels. I believe you take off the rear tires and slide them on carefully
Old Jan 13, 2022 | 06:20 PM
65GGvert's Avatar
65GGvert
I'd like to see a picture of that running board.
Old Jan 13, 2022 | 06:23 PM
DansYellow66's Avatar
DansYellow66
I believe some owners have engaged the rear end of the molding on the retainer at the front and slid them on. I have always had side pipes and never had to do that, so not sure if front tire needs to be removed for clearance - but I suspect so. I would tape off the paint in the area and any burrs or sharp edges on the moldings to protect the paint.
Old Jan 13, 2022 | 09:14 PM
quahog's Avatar
quahog
I'll definitely try the slide on method when I have an assistant available . Thanks for all your replies . I'll try and post a picture later . thanks again Jeff
Old Jan 14, 2022 | 02:38 PM
quahog's Avatar
quahog
I hope this pic comes out
Old Jan 14, 2022 | 06:26 PM
DansYellow66
I think you’re showing your age terming them running boards. But that’s OK, most of us are far past being thought of as young anymore. Hope they slide on OK.
To 67 running boards
