had my front end alignment done and car feels good and steers good. however the alignment shop did not align the rear of the car as he said he does not have
the proper shims? he also stated that the front alignment is the most important and the rear aliignment is not that important. he said my rear alignment was
out 3 degrees.
my question is should i be concerned about the rear? should i take it to another shop and have the rear aligned??? how important is the rear alignment?
thanks for any help and information.
me personally I would want it done . .you can buy the shims online and take them with you to the alignment place. Depends on how much you drive and no its not as critical as the front
What does “out by 3 degrees” mean? What’s out camber? Then that’s a lot. Any good alignment should include a printout of before and after readings both front and rear even if a rear was not performed. Anybody that makes a statement like “the rear doesn’t really matter” I would be looking for a new shop. JMHO. .
out 3 degrees.
The guy is a moron! Stable handling of a C2 Corvette requires rear suspension alignment, particularly toe, to be in a narrow range, and if camber is "out three degrees" the tires are riding on the shoulders.
Do you have a sheet with all all the alignment sheets? If so, post if. If not go to a shop that has modern four wheel alignment equipment with some correct shims to get the toe-in properly set., and get the hard copy of the initial and final settings. Search for threads started by me for how to set rear toe, and also search sport and touring alignment settings.
I was taught back in the late 70's that you always did the rear first and then the front other wise the front could still be out . i would be looking for another shop that has experience in corvettes Bob
YES. Thrust line and center line need to be very close. Then front is referenced from this. Ever seen a car going down the road “dog tracking” sideways? That is what off.
Find a shop that knows how to correctly align a C-2, C-3 Corvette. The tech will have gray or white hair. Bring your alignment specs with you. They are different for radial tires vs. bias ply tires. Lastly, make sure you can easily loosen the pivot bolt and shims. If the bolt is frozen or the shims are rusted, you are in for some work making the parts removable. If not an NCRS car and you have to change out the shims, consider slotted stainless steel shims from a 69 plus C-3. If frozen, prepare to pull some hair out. . Jerry
Having been in the alignment business for 20 years (and having done my fair share of C2-C3 rear ends) this is the issue. Aligning a rusty C2-C3 rear is not worth the money.
I'm going to start a thread on string-aligning a C2 in the near future. I did it on my 67 and it turned out great. There is no one locally I can trust to do it (the expert passed away last year), so I figured it out on my own (like most things).
i'm going to start a thread on string-aligning a c2 in the near future. I did it on my 67 and it turned out great. There is no one locally i can trust to do it (the expert passed away last year), so i figured it out on my own (like most things).
Great timing - I'm in the process of adding Power Steering to my 66 L72 Roadster and 'while in there' replaced the tie rod ends and idler arm along with rebuilding the steering box...with a kit from Gary Ramadei. The other midyear I have that's going to be needing alignment is the 65 396 Roadster that I'm also working on.
Thanks,
Mike T - Prescott AZ
