[C2] C2 vs C3 Header Differences
Exhaust Header Information: The engines were developed using 2-1/8" diameter x 34" long primary tube headers with 3.00" diameter collectors.
Here is more info on the engine:
Cylinder Heads:...Aluminum oval port with stainless steel valves (Intake/Exhaust). 2.19ʺ/1.88ʺ
Chamber Volume: .. 110cc
Ovate (Beehive) Valve Springs ........ 155 lbs. seat pressure at 1.880ʺ installed height
Camshaft: ...... Hydraulic roller tappet .. .527ʺ intake and .544ʺ exhaust
Duration:.... 224° intake, 234° exhaust @ .050ʺ lift
Centerline:... 110° LSA
To make thing more fun, I am using a Borgeson steering box. From what I have found on older threads in both the C2 and C3 sections, McJacks big block replacements, Hedmon Street Headers and Hooker Super Competition headers may clear everything. Sanderson block huggers were also listed. The Hedmans and Hookers may need to be dented for the steering box depending on the thread you read. The ZZ427 uses angle plug heads and has raised .300 exhaust ports.
I called McJacks and he stated his would work on the engine and clear the box. They are a 2" tube with a 2.5" collector. Here is a link to his: 65 - 69 Corvette Big Block 2" Primaries, Factory Cast Iron Replacements - McJacks Corvettes (vetteheaders.com)
The Hedmons have 2" primary and 3" collector and they are long tube.
The Hookers have 1-7/8" primary and 3" collector also long tube. Compare (summitracing.com)
The Sandersons have 1-7/8: primary and a 3" collector. Here is the link. Sanderson BB5 Corvette Header (sandersonheaders.com)
I stumbled across these but say C3 and don't know anything else about them except they are expensive. C3 Corvette Big Block Headers - American Racing Headers
Based on further reading both on and off the forum, it seems that the 500 hp range is the bubble between 2.5" and 3" exhaust and going 1-3/4 to 2" on the primary header tubes.
I'm leaning to the McJack shorty headers as I believe they will clear everything, but I do like long tubes. Of course, this is not a race car so I may never see the benefits of one vs the other. Keep in mind that I have no clue what the numbers on the heads and cam mean in relation to changing sizes of pipes both on the header and exhaust. I would look at comparisons and the head or cam number didn't change much to me, but it changed the recommendations on pipe size.
Don't get me started on the H Pipe vs X Pipe threads............ Thank God for whiskey.
Doug
Too big of header tube diameter will affect low RPM response and torque.
Larry
I don't know what differences there may be in the fiberglass at the front of the floorboards between a C2 and C3, but I would imagine that they are not identical so this may be a consideration. The location of the steering box or even A-arms could also be a bit different relative to the engines position.
