[C2] Battery Removal
Old Feb 7, 2022 | 03:26 PM
gbuente's Avatar
gbuente
Cruising
Default Battery Removal
Having difficulty removing heavy dead battery from 66 Corvette. Is there a technique without removing a bunch of hoses or OTC battery removal straps to assist in removal of the battery.
Old Feb 7, 2022 | 03:31 PM
rowingone's Avatar
rowingone
if you have ac you have an access panel on the inner fender . . some also remove the hood latch catch for better access and pull it out from the top.
Old Feb 7, 2022 | 03:53 PM
C2 Jeff's Avatar
C2 Jeff
It's not fun, but for access, just unbolt the overflow tank and tie it out of the way. If you want to avoid the straps, find a buddy and lift the car and have him push from underneath, it might give you enough height to overcome the angle, which is not great.
Old Feb 7, 2022 | 04:02 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Assuming you don't have A/C. Remove the cables. Loosen the retaining band on the overflow tank closest to the inside of the fender. Remove the other band. Hopefully, your heater hoses let you roll the tank toward the engine and secure it with wire or heavy string. No need to undo hoses. Do it carefully so you don't stress the heater core ends. Remove the bolt that holds the battery hold down bracket at the bottom side of the battery. Set the bracket aside. The object now is to use a battery strap. It attaches to each post. Now, lift the battery perpendicular, it's awkward and heavy. While you'er in there, clean your battery tray. Reverse the procedure for the new battery. Dennis
Old Feb 7, 2022 | 05:58 PM
mikelj's Avatar
mikelj
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
If the battery is a sealed unit, you can flip it on its end on the battery tray, that gives you more room to grab hold of it from underneath. If it is not a. sealed battery, I have wrapped it in thick plastic or a plastic bag to keep it from leaking as you do that. It is a heavy dead lift no matter how you do it.
Old Feb 7, 2022 | 06:51 PM
corvetteed's Avatar
corvetteed
St. Jude Donor '14 thru '26
w/the above; you can also put down a towel underneath to absorb any leaking, or if you happen to let it slip a little while dead lifting it out. Your back is gonna complain pretty much no matter how you do it.
Old Feb 7, 2022 | 10:48 PM
Tooth Doctor's Avatar
Tooth Doctor
Lift with your legs, not your back!😁
Old Feb 18, 2022 | 12:29 PM
gbuente's Avatar
gbuente
Cruising
Thanks. Tied off heater hoses and used brute force strategically
Old Feb 18, 2022 | 12:36 PM
gbuente's Avatar
gbuente
Cruising
Thanks. Pretty much how I did it. Being an engineer, this is a poor design. Obviously, GM doesn't expect you keep the car 56 years!
Old Feb 18, 2022 | 12:39 PM
gbuente's Avatar
gbuente
Cruising
Thanks. Exactly the way it had to be done! Boy, that battery is heavy from a dead lift.
Old Feb 19, 2022 | 02:41 AM
ghostrider20's Avatar
ghostrider20
No, use your upper back, shoulders and neck! Put all the torque to it when your head is at a vulnerable angle!
Old Feb 19, 2022 | 09:51 AM
stellar's Avatar
stellar
No use your head. Ask someone else to lift it.
Old Feb 19, 2022 | 10:05 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it's not the worst thing engineers ever did to car parts locations
Old Feb 19, 2022 | 10:54 AM
CorvetteMikeB's Avatar
CorvetteMikeB
Ask one of your x-wives' illegitimate adult children to do it for you.
Old Feb 19, 2022 | 01:44 PM
wellstroked's Avatar
wellstroked
I hear dead ones are harder to lift….
Old Feb 19, 2022 | 02:13 PM
mblake101's Avatar
mblake101
Default Battery
......dead children????
Old Feb 19, 2022 | 02:33 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Search for a recent thread started by me regarding how I easily R&R-ed the battery from my '60. I have no strength in the grip of my hands and I have serious back issues, yet I changed the battery by my self. You can too.
To Battery Removal
Old Feb 20, 2022 | 12:07 PM
Watershops's Avatar
Watershops
St. Jude Donor '22
As said, find a kid who's strong like bull and smart like tractor.
Old Feb 20, 2022 | 03:51 PM
hundriver's Avatar
hundriver
Default Battery removal
Since I only drive my car in dry, sunny, temp above 50, weather, I removed the heater and associated ductworks. Amazing how much easier it is to charge or remove the battery!
Old Oct 15, 2025 | 01:30 PM
CorvetteMikeB
For a C2 with A/C. These new batteries are sealed. Seems like you can remove the battery with the help of battery strap carrier. Battery could be pulled up out of the engine bay or gently moved to bottom of the car to the cement floor. From the bottom the battery could be placed on it's side and removed from under the car. Do the opposite for installation.
By Michael S. Palmer | 2026-06-03 09:39:05
