Interior paint
Old Feb 7, 2022 | 09:57 PM
OldVetteguy84's Avatar
OldVetteguy84
Default Interior paint
I'm actually getting far enough to begin thinking about the interior of my 67. What paint should I use on the glovebox door, and speaker grill?
Thanks! Tim
Old Feb 8, 2022 | 10:58 AM
berlinlake's Avatar
berlinlake
I'm not sure if it's the same for the door and grill but I used the Corvette America interior dye to paint my center console and it matched perfectly. I used the satin clear top coat to finish it. I think for black a lot of guys use something else but you can search the forum to find previous discussions and recommendations.
Old Feb 8, 2022 | 01:11 PM
leif.anderson93's Avatar
leif.anderson93
Clean parts with PrepSol, Acetone or Lacquer thinner and then apply...(available through Amazon).
Old Feb 8, 2022 | 02:01 PM
OldVetteguy84
I have some of that I used under the hood. Makes sense for speaker grill, but isnt glove box door a glossier black?
Old Feb 8, 2022 | 05:47 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Based on previous threads, I bought a can of Dupli-Color Low Gloss Black Engine Enamel DE-1634. Have not used it yet so can't report on the appearance after use.
Old Feb 8, 2022 | 05:49 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
nope use the semi flat black.
Old Feb 9, 2022 | 11:31 AM
OldVetteguy84
Is that the paint Railroadman suggested?
Old Feb 9, 2022 | 11:42 AM
Railroadman
The pic above is the paint usually used for under the hood. There are different opinions on everything it seems. The paint I mentioned is not the same as the under-hood but I doubt they would be far enough different to bother most people. I didn't record which thread that info came from, it was something on here in the past and the votes at that time were for this one.
Old Feb 13, 2022 | 05:48 PM
OldVetteguy84
Here is my experience with the Dupli Color: I first cleaned thoroughly with acetone, then sprayed. It did not stick, like painiting chrome. I cleaned again and primed. Let it dry thoroughtly then painted again. Overall itwas pretty good, but some areas did not want to take paint. Fortunately I had the whole can to work with. I spot sandedthe bad spots, primed with q tip and resprayed. I actually came out pretty good. Certainly better that the rest of the door which has some corrosion.
I think the slight gloss is pretty accurate. Thanks to all.
Old Feb 13, 2022 | 06:33 PM
ricks327's Avatar
ricks327
I would strongly suggest that you use etch primer before using whatever you decide on your black paint.
Old Feb 13, 2022 | 08:08 PM
Railroadman
Two good suggestions in a row - thanks!
To Interior paint
