[C2] 1964 Column
Old Feb 14, 2022 | 10:31 AM
plaidside's Avatar
plaidside
Default 1964 Column
On my new 64 I notice the upper column was loose so I pulled it apart yesterday and found a bubba fix.
Also didn't they do away with the screw and jam block on the 64?
I will be ordering a new tube, this must be common as I put one in my last 64.
Anyone have a breakdown of this column? I have 63, 64 & 65 shop manuals and I can't find it in them.
Thanks,
Joe
Old Feb 14, 2022 | 10:57 AM
pop23235's Avatar
pop23235
No screw and wedge in 64. The bell casting used was a holdover from 63, but using the tabs and retainer.
Old Feb 14, 2022 | 12:37 PM
plaidside's Avatar
plaidside
Thank you for the reply. That is what I thought but wanted to be sure.
I assume the PO didn't want to replace the tube so he put the wedge in as a shortcut.
Another question, is the column and signal switch bowl painted interior color, mine is blue, or flat black?
Hard to tell from my old stuff.
Old Feb 14, 2022 | 03:03 PM
pop23235's Avatar
pop23235
63 is interior color, 64 up is semi-gloss black as far as I know. Never owned 66, 67. I use trim black. Perfect match.
Old Feb 14, 2022 | 03:10 PM
64L76's Avatar
64L76
If you do not have an AIM for a '64 check out the Paragon on line catalog for C2s. Steering column parts start on page 40 of the catalog. It has excellent blow-up illustrations of all assemblies, including a 64 steering column and all associated components. Actually, the Paragon illustration is a cleaned up version of the one in the AIM. Using the illustration, you will be able to identify all the parts you need to assemble your steering column correctly. https://www.paragoncorvette.com/down...ts-catalog.pdf
Old Feb 14, 2022 | 03:32 PM
Pilot Dan's Avatar
Pilot Dan
Also order a new lower bearing and race as well.
Old Feb 14, 2022 | 05:33 PM
inspectorudy's Avatar
inspectorudy
When I installed electric power steering in my '64, I had issues with the turn signal cam on the steering wheel. I could not get the wheel to close the gap between the wheel and the bell. Come to find out that I had a '63 bell and a '64 tube. I know it was a '63 bell because it was blue on the inside. The bell was 1/4 shorter than the '64 so that made the gap bigger. I was able to grind down the plastic turn signal cam so that it took up some of the gap. To make it look normal, I used black door edge molding on the lip of the bell and it looks like it was designed that way.
Old Feb 14, 2022 | 07:57 PM
plaidside's Avatar
plaidside
Thanks for the info and I hope I do not have the same situation.
Thanks, I just assumed I would find the information in the 63, 64 or 65 GM shop manuals.
I have an AIM and will check it out.
To 1964 Column
