Plug Required?
Old Feb 16, 2022 | 03:51 PM
C2Dude's Avatar
C2Dude
Default Plug Required?
Those of you who have installed a VA heat/ac unit probably had to pull up the carpet and underlayment on the passengers side so as to install the evaporator. On mine that required removing the sil plate. When I did that I found this hole that does pass straight through to the underside of the body. Should this hole be plugged?
Thanks.
Old Feb 16, 2022 | 05:36 PM
leif.anderson93's Avatar
leif.anderson93
You need some sill plugs.
https://www.zip-corvette.com/64-82-d...nel-plugs.html
Old Feb 16, 2022 | 05:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Leif coupe only
Old Feb 16, 2022 | 07:05 PM
leif.anderson93
Leif coupe only
I didn't see where he said it was a convertible but that body mount is only on the convertible. Bet those plugs would work for him, though.
Old Feb 16, 2022 | 07:11 PM
Nowhere Man
after reading his post it doesn’t say if it’s a coupe or convertible. But I am not seeing a body mount bolt. So I would say he has a coupe.
Old Feb 17, 2022 | 07:43 AM
C2Dude's Avatar
C2Dude
My bad guys, she is a 66 convertible. So I'm missing body mounts?
Old Feb 17, 2022 | 07:52 AM
Con's Avatar
Con
This is a 64 conv and yes I think you're missing the bolt.
Old Feb 17, 2022 | 08:09 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
That would be unusual for that bolt to be missing, and it would not come out by itself.
Does it appear to anyone else that there is paint under where the body fastener bolt washer should be, possibly indicating that this bolt was missing when the car was last painted?
Old Feb 17, 2022 | 08:49 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Maybe snapped off?
The pic angle is tough to determine if its missing or broken off?
Marshal
Old Feb 17, 2022 | 09:14 AM
C2Dude's Avatar
C2Dude
So I need to find the right length bolt(s) (I have not pulled the drivers side plate to check but I will), nut and washer and install them. Stainless OK, not a judged ride.
Old Feb 17, 2022 | 09:23 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
I think that mount has a caged nut in the frame mount. Check for threads in the hole. Without the bolt, you may be missing some shims too.
Gerry
Old Feb 17, 2022 | 09:39 AM
C2Dude's Avatar
C2Dude
I'll check for that as well. Guessing you crawl under and with a flashlight, check the shim status. If missing, shim just enough to close the gap?
Old Feb 17, 2022 | 09:53 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
I don't know if you can see them easily. My car has side exhaust and you can't see the mount without removing stuff. If your door gaps are good, then just add shims to fill the gap.
You can adjust the door gap by adding or removing shims.
Gerry
Old Feb 17, 2022 | 10:36 AM
leif.anderson93
I think it's the bad lighting in the OP original picture...kind of an optical illusion. The shadowing is throwing everything off. I see a bolt head inside the hole. A clearer picture without shadows would be most helpful. And, wouldn't the sill plugs work on this hole??
Old Feb 17, 2022 | 10:41 AM
Easy Rhino's Avatar
Easy Rhino
Originally Posted by Con
You see a bolt head in the first (blue car) picture?
I see a bolt head in the second (black car) picture.
In the first (blue car) picture I think I see diamond decking on the floor through the bolt hole.
Old Feb 17, 2022 | 10:47 AM
leif.anderson93
YUP, sure do!!!!!
Old Feb 17, 2022 | 11:10 AM
C2Dude's Avatar
C2Dude
What you are seeing Leif is the decking of my 4-post lift she is on. No bolt there and you can see straight through the hole to the ground. Doesn't sound like you can access that area to install shims without possibly having to lift the body on that side (under car exhaust on mine). If that's the case, plugs are sounding real good to me. My door gaps are good.
To Plug Required?
Old Feb 17, 2022 | 11:13 AM
elwood13's Avatar
elwood13
I thought I saw a bolt at first but I believe it’s all shadow and optical illusion. C2Dude, I don’t think you will be able to see it from under the car. Here is a pic of my bolt and a few pics of the shim stack underneath. I had to use my scope camera to see the stack.
Old Feb 17, 2022 | 11:23 AM
elwood13's Avatar
elwood13
I stand corrected. Here is a shot looking up between the frame and the rocker panel.
Old Feb 17, 2022 | 02:10 PM
C2Dude's Avatar
C2Dude
Those pictures are real helpful. I'll get under her and see what I have. Thanks to all for the guidance.
