[C2] Tunnel Insulation
Old Feb 18, 2022 | 08:24 PM
plaidside's Avatar
plaidside
Default Tunnel Insulation
Can new tunnel insulation be installed with the transmission in the car?
Old Feb 18, 2022 | 08:29 PM
66jack's Avatar
66jack
Nope...
Old Feb 18, 2022 | 09:30 PM
bauto's Avatar
bauto
you might be able to split it in 2 pieces and then use alum. tape to fix the seam
regards Bob
Old Feb 19, 2022 | 01:02 AM
Tooth Doctor's Avatar
Tooth Doctor
I think it can be done. I just had my transmission out for rebuilding and replaced the insulation. I think if you cut a slit for it to fit around the shifter, or removed the shifter, you could do it.
To Tunnel Insulation
