Ignition Switch
Old Feb 20, 2022 | 10:46 AM
D67's Avatar
D67
Default Ignition Switch
I am restoring the instrument cluster in my 67 and using Roger Scott of Corvette Instruments to rebuild the gauges. (very easy to deal with)
I also ordered some replacement switiches from Corvette Central, a Wiper Switich, Lighter Retainer and Ignition Switich none of which fit into the holes of the Dash.
I am doing some creative filing on the Switches to make them fit, but my issue is with the replacement Ignition Switch, it does not have the Light Housing as does the origional Switch (673 2). I did not notice a light bulb when I removed the switich nor do I see what a bulb would illuminate. Can anybody comment on this issue.
Old Feb 20, 2022 | 02:27 PM
John 66 Vette's Avatar
John 66 Vette
It's nice to see Roger is still in business. He did my Cluster in 1995 and it still looks new.
Old Feb 20, 2022 | 09:08 PM
R66's Avatar
R66
What is wrong with your original switch? They can be disassembled and lubricated with a little effort. The original grease was lithium and turns to mud over 50+ years.
Old Feb 20, 2022 | 10:29 PM
DonnieP73's Avatar
DonnieP73
This is the switch that I got to replace my ignition switch on my 67.
https://www.zip-corvette.com/66-67-i...t-housing.html
Donnie
The bulb will be a 1445 and the wire will be grey for the socket. The light will appear as a light ring around the key ignition.
Old Feb 20, 2022 | 11:33 PM
D67's Avatar
D67
Thanks for the input, I will reorder from ZIP
To Ignition Switch
