My battery is fully charged. Connections are good at firewall including red wire. When I turn the key I just get a click and the courtesy lights go out. I then go take the negative battery cable off of the battery and place it back on again. My courtesy lights come back on and then I turn the key to start and rinse and repeat. I am either thinking bad ground at the starter or a bad starter. Any other ideas or help would be greatly appreciated.
Jay - How old is the battery? When you take a battery into your FLAPS, I believe it's tested by putting a load on it. The static numbers can be fine at a glance, like 12.4 or so, but when they test them, it's typically more than just a VOM showing the charge number.
It's always a pain to haul a battery out of an old Vette but maybe take it down to the local auto parts place and let them test it.
Mike T - Prescott AZ
I agree with everyone. The battery is about 3 years old and seems to be very strong. I will check all connections at starter and solenoid and then remove battery for a load test. I am just confused why the courtesy lights go out and I get the click and then I remove the negative cable and put it back and the lights come back on.
before you remove anything I would use an insulated screwdriver to join the contacts on the solenoid and have someone then turn the ignition on . . if you then get the starter to turn over it is not the starter but rather the solenoid . . if the starter doesnt turn over, the problem is the starter itself. Diagnose before removing parts! I know in my car removing the battery is a pain, maybe not so much in yours.
Well here is my update. I cleaned all of the starter/solenoid terminals and wire connectors. I tested the battery under load and it is very good and strong. I cleaned battery cables and terminals. I was ready to start and turned the key and had exactly the same result. Courtesy lights go out and a click and nothing else. I was lying on my back with tools in hand to pull the starter and something told me to go and take the key out of the ignition and then put it back in. I did exactly that and the car started immediately as normal. I guess my ignition switch is starting to go bad even though I have never had that problem before. I then started it another half dozen times over the next hour and it started every time.
Now on to the next problem. I need help from a Holley carburetor expert. It is leaking gas from the vent of the bowl closest to the firewall. I guess that the float is sticking. I gently tapped on it to see if I could free it but the vent cap just came right off and then was leaking even more. I gave up at that point and figured I was not going to be lucky a second time in one day. I will start a new carb problem thread.
Thanks to everyone who helped me with my starting issues.
Typical of bad connection at the battery or the starter. Clean the battery posts and connections at the starter and ground to the bellhousing. If you still have the problem, put a jumper cable between the negative and a good ground and try it. Then put a jumper cable between the positive post and the large terminal at the starter. This will tell you if you have a bad cable on either side of the battery. I use NO-OX (or a good electrical contact grease) on the battery posts and connections to improve the connection. Just a guess.
The problem was my key in the ignition. Problem appears to be solved.
Jay
I don't see how the lamps are tied to the ignition switch. I think you are still looking for a bad ground or something common to both. The ignition switch sends 12v to the solenoid (purple wire) in the start position, but has nothing to do with the lamps. Anyway, hope you have it fixed.
Very good point as it was acting like a grounding problem. It is continuing to act normal but if it happens again I will go back to the beginning and start over again.
If you loose power to everything, it could be the red wire contact in the firewall connector in the back of the fuse box. There are multiple posts on here about it. Other than that, the battery cables, connections at the battery and starter and feed from the horn relay are common. Hoping one of the expert electrical types chime in for you.
Since the starter heavy leads don't go through the ammeter I doubt it would show a -40 amp draw I'm thinking. My neighbor had the same issue with his C3. Turned out the wire that activates the starter solenoid was rubbing against the block and wore through the insulation for a short. Was able to confirm it by unplugging the coupler (don't know if a C2 has one) to the solenoid wires and the draw stopped. Just a thought.
Ive had the same problem with 67...........checked everything finally determined it was the red battery wire it was aged out it had started to corrode on the inside just enough not let a full charge to the starter , changed it out and problem solved
