[C2] 427 - Compression Required for an L-72 Solid Cam
Old Mar 7, 2022 | 03:18 PM
Vet65te's Avatar
Vet65te
I've seen the Speed Pro L2268 on Summit's site for the last couple years but they've only shown the .030 and .060 over sizes. And, they list the .030 version as having .300 dome and a volume of -36.30. I've been using the volume specs of -16.80 on my L2300-.030 pistons when calculating the ballpark compression ratio. So, if that's not exact, probably only a small change in the final numbers, I'd suppose.
Summit Racing Part Number:
SLP-L2268NF30
UPC:
019826077608
Piston Rings Included:
No
Bore (in.):
4.280 in.
Bore (mm):
108.712mm
Stroke:
3.766 in.
Engine Stroke Type:
Stock
Rod Length:
6.135 in.
Piston Style:
Dome, with single valve relief
Piston Material:
Forged aluminum
Compression Height (in.):
1.765 in.
Dome Height (in.):
0.300 in.
Piston Head Volume (cc):
-36.30cc
Mike T - Prescott AZ
Old Mar 7, 2022 | 05:17 PM
Dad's '66 427's Avatar
Dad's '66 427
2020 C2 of the Year Finalist - Unmodified
SLP-L2268NF30
UPC:
019826077608
No
Bore (in.):
4.280 in.
Bore (mm):
108.712mm
Stroke:
3.766 in.
Engine Stroke Type:
Stock
Rod Length:
6.135 in.
Piston Style:
Piston Material:
Forged aluminum
1.765 in.
Dome Height (in.):
0.300 in.
-36.30cc
Thank you!!!
