WCFB Carb
Old Mar 11, 2022 | 07:53 PM
vanessa565's Avatar
vanessa565
Default WCFB Carb
Just wondered if anyone can shed some light on a couple of WCFB carburetors I have, one was on my 1965 Corvette when I bought it in 1972, the other I purchased in 1974 from my local NAPA store. Both have the following numbers Air horn #6-1672 carb body # 0-1241, throttle base plate #1579. I think the Air horn number and the base plate #1579 are correct for 65 Corvettes with 250 hp 327. The carb body # 0-1241 seems to be incorrect for the 65's.Both carbs have been restored, re-plated for modern fuels, one has been on my Corvette for about 2000 miles over the past several years, the other is still in new condition, never been put on a car. Any info anyone could share would be appreciated.
Old Mar 11, 2022 | 08:54 PM
plaidside's Avatar
plaidside
There should be a number stamped in the right front base flange.
Old Mar 11, 2022 | 09:00 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
OP is saying WCFB which were not on 65 Corvettes. Only Carter & Holley.
Old Mar 11, 2022 | 09:22 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
What carb did the '65 250hp have?
Old Mar 11, 2022 | 09:26 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Wait..... what? WCFBs were made by Carter. I don't get the distinction you are making.
Old Mar 11, 2022 | 10:42 PM
3030cam's Avatar
3030cam
WCFB = William Carter Four Barrel
Old Mar 11, 2022 | 10:46 PM
leif.anderson93's Avatar
leif.anderson93
Don't believe so...Carter Wrought Cast Four Barrel
Old Mar 11, 2022 | 11:35 PM
3030cam's Avatar
3030cam
It's been called by both names. Also called "White Cast Four Barrel".
Old Mar 12, 2022 | 07:22 AM
Redbird's Avatar
Redbird
My error, I was thinking WCFB vs AFB.
Old Mar 12, 2022 | 07:53 AM
jim lockwood
I'm still not following. Both of those are Carter carburetors.
Old Mar 12, 2022 | 06:44 PM
SWCDuke's Avatar
SWCDuke
WCFB was used on the base 327/250 HP engine from '62 to '65. The 327/300 became base in '66 but with a Holley rather than the AFB used from '62 -'65. It appears that GM and Carter had a falling out. Some of you may remember the late Dale Pearman. He was a big '62 and AFB guy with a great sense of humor. He always referred to Holleys as a "packaged leak."
Duke
Old Mar 13, 2022 | 03:20 PM
Boyan's Avatar
Boyan
Default Carb
I’m interested in the re-plating for modern fuels….please, I want to know more
Old Mar 13, 2022 | 04:57 PM
jim lockwood
Probably a misunderstanding. I've never heard of such a thing. What is important is that any gaskets, o-rings, or other seals can withstand the ethanol in most modern motor fuels.
Old Mar 14, 2022 | 09:37 AM
Tom Spence's Avatar
Tom Spence
Is there a book or manual that lists the application/numbers each year should have. My old JRM only shows carb tags.
This gives me the incentive to get the numbers off mine. Tag says 2669 but I know it's a later application. Thx
Old Mar 14, 2022 | 10:10 AM
Redbird's Avatar
Redbird
Maybe this will help. It is from the 63-64 NCRS Judging Manual.
Old Mar 15, 2022 | 12:03 AM
Tom Spence's Avatar
Tom Spence
Thank you RB. Looks like I have a 1964 main body and top. I'm not able to check for a number if any on the lower front base in front of the choke if that means anything. I'm going to advertise it for sale probably on the DB Classifieds and want to be accurate to what it is.
To WCFB Carb
