Solid lifter question
Old Mar 16, 2022 | 02:39 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Solid lifter question
Ive chosen the LT1 cam for my rebuilt engine. I noticed the new solids come with a small hole on the lobe surface.
Anyone have experience with these? Pros or Cons?
Old Mar 16, 2022 | 07:25 AM
69ttop502's Avatar
69ttop502
Great thing, the small edm hole on the lifter. Helps with oiling to the lobe/lifter contact point. Definitely something you want to have these days. I am running the LT-1 cam in my 62 340 horse car. You will like that cam.
Old Mar 16, 2022 | 08:06 AM
66427-450's Avatar
66427-450
Originally Posted by 69ttop502
Great thing, the small edm hole on the lifter. Helps with oiling to the lobe/lifter contact……
agree I’ve used them for years. I suppose someone could argue about oil flow diversion, but I’ve never experienced any issues, that said, I’ve always use high-volume/ L-88 oil pumps. (I’ve used them successfully/without issues, in small blocks as well)
Old Mar 16, 2022 | 11:38 AM
Factoid's Avatar
Factoid
When you compare orifices, the rockers still win. Great mod to have!
Old Mar 16, 2022 | 11:47 AM
TAlvarez's Avatar
TAlvarez
I used the Crower version of these on a 427 Ford side oiler a few years ago to hopefully provide a bit of extra protection for the sft cam. Seemed to work out very well.
Ted
Old Mar 16, 2022 | 11:58 AM
Muttley's Avatar
Muttley
I used EDM lifters with an LT-1 cam on my recent build. Only a few miles on the engine, but so far so good.
Old Mar 16, 2022 | 12:24 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I have an actual LT-1 in my 61.. with the stock edge orifice lifters.
I believe they used these to limit the amount of oil in the top of the motor under long, high-RPM runs.
Too much of a good thing!
To Solid lifter question
