'61 Fuelie Problem
What is the ambient temperature when the engine runs roughly?
When it runs roughly, is the engine idling or are you under way? If under way and engine runs roughly, you've got other problems.
Describe in detail your hot start procedure..... if done correctly, the hot engine will re-fire instantly, even if it subsequently runs roughly.
When the FI was rebuilt, how was the air/fuel ratio calibrated?
If fuel percolation is the issue, postings #5 and #7 in this thread detail the most effective solutions known:
curing FI fuel perc, click here
Regarding premium fuel, no, there is nothing you can do to it to reduce its tendency to percolate in an FI engine. Fuel percolation in Rochester FI is a byproduct of engineering decisions made 67 years ago.
The 100 octane costs 9.99 a gal.
Google it for a station near you.
By the way, I also removed ethanol from 91 octane pump gas (its a pretty easy process) and it didn't seem to help much. I spoke to a Sunoco technician who said that removing ethanol would probably have only a minor effect on the vaporization pressure since it comprises only 10% of the volume of the pump gas.
Finally, you should talk to Jim Lockwood about the modifications he can make to your system to alleviate the percolation issues.
I will bring the beast back to Ed at Corvette Services on Monday to see if he can do some additional magic but I think it will be limited to adding nylon bolts to help insulate the spiders and perhaps some additional tuning. He sourced the new F/I unit for me so he might be the best person to address the setting for the air/fuel mixture.
Is there anything else you can suggest? Did your modifications to recirculate fuel like the later Stingray F/Is and replacing the copper fuel line with steel help. If so, would you be willing to make these modifications to the beast? We're in California so I could drive/transport the car to you. I will try feeding it AV gas once I run through the rest of the racing gas to see if it continues to run better
Many thanks for your help!
Tom
You may be having a fuel perc issue but my interpretation of your symptoms is that something else is also happening. The reason being that fuel perc stops instantly once the engine has a load applied. Instantly. Like flipping a switch. So since roughness continues after the car is moving, it isn't percolation.
As to how much my modifications help, in the thread I previously linked, see posting #231.
I'm more than happy to modify your FI unit if you want me to. And if you are willing to deliver the unit to me, that would be far better than shipping it. Going forward, we should probably take this off line.
Jim
I completely rebuilt my Rochester about three years ago with the help from Jim. He walked me through the calibration which came out awesome.
So what do I attribute my successful taming of the Rochester FI. Well number one to having most of the parts replaced with new ones and the very successful tuning. But the number one contributor, IMHO, is the marine blower that I have cooling the spider and secondly the non-ethanol 90 octane gas I use. Two simple thing that tamed the beast completely.
Jim I already installed the coil over suspension on the 1935 Ford and tomorrow we are starting to install the engine and the transmission. SBC 350 ci/354 hp/416 ft-lb Dyno tested.
Sleepy Jim
You can make your own non-ethanol gas from the ethanol gas. It is fairly easy once you have the set up. There are several postings on how to do it. If I would live in California I would most certainly would make my own non-ethanol gas, or better yet move to Florida. If you are interested let me know and I will post the link to the posting. I did a lot of work trying to solve the percolation problem and like I said the blower is the number one followed by the non-ethanol gas.
I am not saying this because I red it or someone told. It was my thorough testing that yielded the results I achieved. The non-ethanol gas is a most. But you need to cool the spider and the non-ethanol gas both.
Regarding the blower it is a very simple set up that can be reversed in not more than 10 minutes. If you want to show your engine and not have the blower showing; it can be removed in not more than 10 minutes.
Good luck
Roberto
I plan on isolating the F/I from as much heat as possible with the nylon bolts idea and installing an electric fuel pump. My next step will be to add your idea for the fan and ducting to cool the spider hub. Finally, I'll try to Shanghai Jim Lockwood to dial in the unit. My cleaver plan is to convince Jim that he needs to take an extended vacation to Santa Barbara. If that fails, I'll resort to the old "Hey Jim, does this handkerchief smell like ether to you"? Then it's just a matter of popping him in the trunk and .... I may be revealing too much.
I did hit the local cars and coffee this morning to catch up with a guy that has been running same '58 C1 with F/I since 1964. He says that the car works perfectly with the local 91 octane gas with ethanol, but has apparently made numerous modifications to the system. At least there's hope.
Good luck
Roberto
I have removed ethanol from our California 91 octane fuel using the water method. It’s an easy process, but I found it did not solve my percolation issues. I have not tried it in conjunction with a cooling fan as of yet. Have you tried running ethanol fuel with your blower and does it still have issues? Curious to know how much of a difference it makes.
I did a complete restoration of my Vette as it was sitting for about 5 years and had deteriorated to a very bad condition. I did not have to do the paint as it has the original in excellent shape. But every thing else was fair game including the FI. We experimented with many things to address the percolation issue and did it methodically, I bought, I believe it was 100+ Octane racing gas to no avail. Only when we installed the blower and I used the REC-90 did it completely got fixed. We tried the blower by itself using E10 gas and it improved tremendously but once in a while threw a tantrum. When I switched to REC-90 mission accomplished.
So if you do the blower alone you will get a very significant improvement but if you want 100% then you need non-ethanol gas. I am a retired engineer so I was very methodically experimenting with the different solutions changing one variable at a time. You need to cool the spider and use non-ethanol gas. Cooling the spider means using forced convection to cool it i.e. a 120 cfm blower. Insulation IMHO will not do it.
California Recipe try it you'll like it - CorvetteForum - Chevrolet Corvette Forum Discussion
I personally do not care to show my car. I had it almost five years and I am yet to be asked to see the engine. To me showing the car means driving it around town and enjoy all the people honking and giving me the thumbs up. I do not have the patience to sit the entire day showing the car. Besides I am super busy right know Hot Rodding a 1935 Ford Convertible. I hardly have time to take the vette out for a ride.
My blower set up is very reversible and you can take it out in abut 10 minutes with no trace of its existence. So if you go to a show to show your car and you are driving the car, when you get there open the hood and take out the blower set up. Before you depart put it back on.
My car is all original including the mufflers, except the blower. If someone is looking at the engine and asks what that is, the answer is that there were a handful of vette that had an experimental set up to address the percolation problem, Mine is the only one left with that option.
By the way do not be fooled with the concept of how simple the set up is and thinking that it is amateur cheap looking. I used Home Depot parts and a West Marine blower and fabricated the set up that looks very professional. It works and it is simple. If the blower fails it will cost me about $30 to replace and about 10 minutes to change.
Fuel Injection Percolation Issue Improvements - CorvetteForum - Chevrolet Corvette Forum Discussion
Regards
Roberto
