‘66 stumbles under throttle load
But there is one major change that I had to make and that was the timing. You said that you had set it at the factory recommended 4* btc. That won't work. And after Dave Fiedler sent my distributor back, he recommended that I set it at around 8* btc initially. Then I timed it the "right way"and that was using my dial timing light to set timing near the peak rpm power curve. Try setting it at 28* at 4,500-4,600 rpm, .lock it down, then let the timing fall where it is at idle. I idle at 600-650 rpm and timing is at 12* btc with the vacuum advance line plugged. After I made this change, the response was immediate. And it's run perfect since. Starts right up, no detonation, and screams in every gear.
I did notice that you had this same issue last year when you posted on this subject. And then you also pointed out the factory timing setting (which you can forget forever). https://www.corvetteforum.com/forums...te-427-bb.html
I hear you and others that a dial back light would be helpful as well as starting with maybe 6-8 degrees BTDC.
I can do that timing adjustment once I’m certain I’ve sorted the possible plug wire debacle out.
I will look for a dial timing light to refine the settings. I am using a dwell meter which I didn’t have before as it had e-spark.
Next, check the coil. A failing coil can cause all kinds of erratic symptoms that have you chasing your tail.
Next pull the spark plugs and have a look at those. Then install a known good set of plug wires and ensure correct placement and orientation. Set timing at 8*BTDC.
Look for loose electrical connections at the coil, or shielding that is grounding or shorting wires.
There were four wires with questionable crimps at the plug boot end. The folded over conductor extended out under the crimp noticeably back away from the plug end.
I’ve spoken to Moroso and visited them as they are local. They are one of the most reputable plug wire companies out there.
They told me the conductor gets folded over and the crimp should hide it. No tails extending out etc.
I then used the new Moroso set I have, made sure the connections were good and timed it for 7-8 btdc.
The car started right up, choke ran fine, I adjusted the idle and took her out. The car runs better for sure than yesterday but still does break up under harder acceleration but much less so than yesterday at 4 btdc. I really do feel it is improved tho.
I ordered a dial timing light and while I may make another run at 8-10 btdc I plan to mostly focus on using the better timing light to time it at higher rpm.
I think I’m closing in on it. I appreciate everyone’s help. Btw, the new carb in the car as of yesterday was restored by “Phil” in NJ and I spoke with him yesterday. It was bench tested and aside from an idle adjustment I don’t think that’s anything I need to worry about. I think I just need to tweak the timing even more.
Oh, and decide what to do with the crappy Zip wire set. I could fix the crimps at Moroso or just call Zip and see what they say.
Zip allowed me to send them back and get another set. If it is the same low quality I’ll decide at that point if I play with the crimps or do something else. with the new Moroso wires in it that variable is gone. The coil was new too along with points, condenser, cap, rotor, ballast and plugs. Vacuum checked good.
Right now it’s so much better that I’d do believe another timing adjustment with the dial timing light at cruising rpm may do the trick. That light comes tomorrow.
The car is a lot better from the first start after the initial short at the battery. Everything is new so I really hope the timing just needs a little more advancing.
I have seen two suggestions for that and wonder if you guys have other numbers?
vacuum blocked, car warmed up.
28 degrees @ 45-4600
or
28 degrees at 4000
One or perhaps both of the above settings should result in maybe 12 degrees at a 650rpm idle, vacuum blocked.
My car is currently at 8 degrees idle vacuum blocked and isn’t happy on harder throttle runs so one of the above settings is obviously a big change that I am hopeful will work well.
Any suggestions are appreciated!
or
28 degrees at 4000
Ignore the above - misread the figures and somehow thought it was 40°-45° advance!
I'm sure you have already been advised to contact Lars and or SWC Duke for their timing papers. Just follow their steps and you will be pleased with the results. Also remember that timing affects your carb but your carb won't affect your timing - you'll be doing a little back and forth adjustment with the carb as you work the process.
I would still like Lar’s or SWC Duke’s tuning papers if possible for minor tweaks.
When I started this project following the initial short I had a cheap timing light. I bought a dwell meter on eBay to complete the points conversion.
Today with a new dial timing light I discovered my dwell was 22 - not the 30 my eBay meter said.
I set the dwell at 30, idle timing at 10 degrees and that gave me 24 on the meter at 3600rpm.
I ran it and it’s almost perfect. Way, way better. At full throttle (hadn’t done that in a while really) I felt a very minor hesitation perhaps and it dieseled slightly at shutdown. I had the idle too high when I left but just figured I’d tweak that after the run.
I just set the idle and added 1-2 degrees more into it so I think I’m at 35-36 total now, 700 or so idle and 30 dwell.
I’ll run it again but the high idle probably was the cause of the dieseling and the additional 1-2 degrees advance will probably be nicer.
The motor feels really strong now with an immediate response. Like I said, I can probably tweak it some but the freakin bad dwell meter (and bad wires, and poorly adjusted carb etc) was confusing the issue.
I'm not following how you had it at 24° (at 3600) then increased by a couple ° and now believe it's 35-36°.
You can send both guys emails through the forum; Lars' direct email is v8fastcars@msn.com tell him you are looking for his timing paper, vacuum advance paper, and Holley tuning paper (if you have a Holley that is). I believe he and Duke have co-authored some info too.
You don't set/measure dwell with a timing light.
Did you??? Or did you use the "dial timing light" to set the timing at 30? BTW, using the timing light with the dial set to 36, the timing mark on the flywheel should be steady at the pointer on the 0 degree mark at 3,000 RPM with the vacuum advance disconnected/plugged.
When you change the dwell (i.e., point gap) you also change the timing.
IIRC, You get the car to idle at the desired speed and set the point gap through the window in the distributor cap using the dwell meter so that it is about 32 degrees (IIRC) on the meter. The dwell is now set.
Disconnect and plug the vacuum line to the distributor. Loosen its hold down nut. Then use the timing light, set at 36 on its dial, and rotate the distributor until the timing mark steadies at the 0 degree mark.
Good advice............but OP needs to clearly understand that he must set his maximum 35/36 degrees at a point where the timing advance no longer increases with RPM. For my 67 small block 327/350 HP engine, this maximum point is 5000 RPM. That is a factory number. Most folks will not go this high, and will stop beforehand.........resulting in an incorrect timing number.........and one which could lead to detonation later during operation.
The best scenario is to modify the distributor weights and distributor advance slot so that maximum mechanical timing is "all in" at around 2800-3000 RPM (4 speed car) and is 36-38 degrees total (initial + centrifugal = total mechanical = 36/38 degrees). A number of 35/36 degrees that you advise is a few degrees low for many cars...........but is a very good and conservative number. I prefer 36-38, or even as high as 40 if the car owner knows what he is doing, and it fits his car. But higher than 36 degrees may require adding some special octane racing fuel to the tank........just for insurance.
Larry
My dwell was set using an eBay dwell meter.
It was off and I also had bad plug wires which combined made it run bad after I had changed over to points from E-spark.
The new timing light I have you can dial in the advance and also look at batt, rpm and dwell.
It was on this timing light I measured dwell today at 22. This, with new Moroso plug wires and everything else mentioned.
I set the dwell at 30 thru the adjustment window on the distributer cap. It stays at 30 running the car up.
I now have 35 btdc at 3600rpm and I think it’s 12 at idle. I intend to check it one more time but it seems to run very strong now.
Sorry about the terminology.
Big block cars are good at around 35-36 degrees MAX as Dan already stated.
Larry
