Disc Brake Conversion Kit
Old Apr 5, 2022 | 12:19 PM
RandallCole's Avatar
RandallCole
Default Disc Brake Conversion Kit
I think I need some help.
I have a 1962 and I am trying to do a front disk brake conversion.
Here is the kit I bought. https://www.ecklers.com/1953-1962-co...ails_tab-title
The problem I am having is the rims. "Requires the use of a 15" wheel designed for disc brakes. Use the template to verify wheel fitment. Rotors have a 5 x 4-3/4" Bolt Pattern. Track width changes by 0.500" per side."
But it does not seem that I can buy them anywhere or even get them custom.
Has anyone else done this? What are my options? Thanks in advance guys.
Old Apr 6, 2022 | 10:21 AM
dmtparker's Avatar
dmtparker
I have the disc brake conversion on my 62 (used one from Zip, but probably the same - uses Camaro discs, I forget the year). I have 15x7 Rally wheels (off a 68 or something like that) and no problem whatsoever.
Old Apr 6, 2022 | 10:30 AM
Plasticman's Avatar
Plasticman
Mine came from the source to Ecklers (at the time - about 2006).
I am using American Racing TTD 6" (15" dia.) rims, with no issues.
Plasticman
Old Apr 6, 2022 | 01:08 PM
RandallCole
Thanks, guys.
Old Apr 6, 2022 | 02:23 PM
toddalin's Avatar
toddalin
You should be able to use the Chevy Rally wheels, but you need to find the ones with the correct offset as there were a few offered. The rally wheels will then take the derby caps/beauty rings, or you can fit the typical wheel covers.
Old Apr 6, 2022 | 07:13 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I use American Racing on my 60 with no problem. It's also a disc brake conversion kit. Track tested to 118 mph in the 1/4.
To Disc Brake Conversion Kit
