1954 Alignment Shims?
Old Apr 21, 2022 | 09:58 PM
woodrow2002's Avatar
woodrow2002
Default 1954 Alignment Shims?
I just ordered a front end suspension rebuild kit that includes the front alignment shims (1956+) and states they can be retrofitted on the 53-55 models. I am curious, has anyone from those earlier years used them and were the results positive?
Old Apr 21, 2022 | 10:02 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
You can
The alum shims give additional caster which increases wheel returnability
Yes - originally - 53 54 55 did not have them
Yes you can retro fit them
They do not pass judging but if you dont care about that you can use them.
Old Apr 21, 2022 | 10:10 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You can take what Chris said to the bank.
That said, my unrestored '54 #3300 does NOT have the shims and I don't miss them. The steering is easy and the car is delightful to drive.
In contrast, my '60 does have the shims and requires considerably more effort to turn.
Old Apr 21, 2022 | 10:26 PM
woodrow2002
That's mainly what I was asking, how it would impact drivability. I'm not going for judging, just to make it more fun to drive (I've pulled the 235 and putting in a custom built up 261 to go that McGurk suggested upgrade for that era).
Old Apr 21, 2022 | 10:44 PM
jim lockwood
A friend has a '53 with a "built" 261 and a 4 speed. The car is downright spunky! You're gonna like yours, I bet.
Old Apr 22, 2022 | 08:12 AM
csherman's Avatar
csherman
What the shim does is add positive caster
It will make the steering easier and the wheel will return quickly and the car will feel more stable.
Your build sounds fun !
Old Apr 22, 2022 | 08:22 AM
jim lockwood
Adding positive caster increases steering effort.
Old Apr 22, 2022 | 08:28 AM
plaidside's Avatar
plaidside
I agree, the more caster, the more the wheels want to return to center.
Old Apr 22, 2022 | 08:34 AM
TR54's Avatar
TR54
C1 &C2 Fan
I would love to see more on your build. Please consider posting some more info and photos as you go along.
Old Apr 22, 2022 | 09:57 AM
Ktholin's Avatar
Ktholin
I added the shims to my 55 when I rebuilt the front end. I am happy with the result and have not noticed an appreciable increase in steering effort. It handles very well on the road.
Old Apr 22, 2022 | 03:56 PM
csherman's Avatar
csherman
Thanks Jim for the correction - type fast than my brain works sometimes....
Old Apr 22, 2022 | 04:40 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
The additional caster the shims provide increased high speed stability. if you aren't driving 80-100 MPH or more, you would probably see no benefit.
The shims do make the steering wheel much harder to turn when stopped on rough pavement if you have modern wide tires (my tires have tread width of somewhere around 7"), it isn't really noticeably more effort if you run skinny bias ply tires.
Doug
To 1954 Alignment Shims?
