Nomenclature
I’m sure most of you have run across the same problem. Even the repro houses differ in what a part is called, as do the repair manuals, etc.
I need to replace the yoke on my driveshaft. Everybody in the world calls it a driveshaft, at least in my part of the world, been calling it that since I was old enough to hold a wrench. Evidently somewhere along the way someone started calling it a “propeller” shaft. A propeller shaft!! Well, if it is a propeller shaft, then I’m missing a propeller!
The old paper GM P&A catalogs have indexes - for the whole book, and then one for each group. So sometimes if I'm looking for a particular part I do a "noun search" That is, I look for the part name in either the whole book index or the applicable group index if I know the group, but some parts, in addition to having uncommon names, aren't always in the group that seems obvious.
A good example was back in the seventies. A friend's new '76 Cosworth Vega was missing three anodized aluminum trim pieces that were part of a custom exterior package option for common Vegas, but were included with the Z-09 Cosworth Vega Special Performance Equipment Package.
Of the three, one went across the bottom of the grille, and the other two from both ends of the center piece, then wrapping around the bottom of the plastic headlight housings. The dealer found the center piece in Group 1, Coolant, Grille, Oil System, but they couldn't find the end pieces. At the time I was buying a lot of parts for my SWC from the same dealer, so on a trip to order or pick up some parts I said let me give it a try. I probably spent about half an hour but finally found them. I looked at Group 12, Body Moldings, Sheet Metal, Group 8 Front End Sheet Metal, heater, and maybe some others, but no dice.
Finally, for a reason I can't remember, I looked at Group 2 Chassis Wiring, Lamps and found them. Go figure!
Duke
"Anti-roll bar"...one of my pet peeves. Functionally it is a pro-roll bar. Originally called a stabilizer, its purpose is to stabilize or harmonize the wheel loads on an independent axle pair. In a turn, outside wheel gets loaded the link(a torsion spring) applies a corresponding load to the inside wheel, stabilizing the pair. Probably became an "anti-roll bar" when somebody stuck it on a straight axle thinking it would be a good idea - it isn't.
Duke
Duke
Dom
