[C1] Turn Signal Problem
Old Apr 26, 2022 | 05:37 PM
sgorman3's Avatar
sgorman3
Default Turn Signal Problem
I suddenly began having a problem with my turn signals. My right turn signal operates fine but, when I actuate the left turn signal, it just stays lit (no flashing). The lights will go off when I recenter the handle. Since the right side flashes fine I'm pretty sure that the flasher is fine. Any thoughts?
Old Apr 26, 2022 | 06:01 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
It can still be your flasher. Replace it first.
Had the exact same thing happen ona 1966 Chev, and 1989 Chev Chevs, decades ago, one side would flash, other wouldn't.
Also, make sure "all" the bulbs light up on each side.
Doug
Old Apr 26, 2022 | 08:34 PM
leif.anderson93's Avatar
leif.anderson93
OP doesn't state what year his car is nor is his profile filled out so we can hazard a guess. Your bulbs have two filaments in them...one filament for parking light and the other for brakes/turn signals. I would start with the easy stuff and replace the offending bulb first. As mentioned, it could be the flasher but my money is on a burnt filament,
Old Apr 26, 2022 | 08:43 PM
sgorman3's Avatar
sgorman3
Sorry guys...my car is a '61
Old Apr 26, 2022 | 10:04 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
First - are the wheels centered - if not I have seen this happen when the wheels are not centered
works fine when moving or turning
also the repro turn signal switches are junk - I have seen this issue with the switch as well
Old Apr 26, 2022 | 10:35 PM
sgorman3's Avatar
sgorman3
Wheels are centered. Doesn't matter what position the wheels are in.. I do have a repro switch installed
To Turn Signal Problem
