Adding clear fuel filter
Old May 2, 2022 | 11:29 AM
vetteman061's Avatar
vetteman061
Default Adding clear fuel filter
Hello,
I have a '61 Corvette with a 327. I need to add a clear fuel filter to the line and have two questions. How can I make room for the filter with the hard line, and what is the best clear fuel filter to use?
Thanks,
Brandon
Old May 2, 2022 | 11:57 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
If I was going to add a clear filter I would put it in the rubber hose from the frame line to the pump inlet line.
Tom
Old May 2, 2022 | 12:04 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
What’s wrong with the filter in your carb and soak in the tank.
Old May 2, 2022 | 12:42 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Without getting into why, and to answer the question you asked, the Rochester carburetor, with the center inlet, makes it difficult to use the bowl type glass filter. It looks like it would hit on the thermostat housing. The afb with the inlet offset clears ok. I guess you could rework your hard line out of the carb with an ell if you are determined to use it. I am a fan of the Rochester carbs over the Carter wcfb. You could actually make it look pretty nice if you are handy at all.
Old May 2, 2022 | 01:09 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
If you must add a clear filter, I recommend making a new hard line made from scratch to plumb it. Save your existing hard line in case you ever want to undo the change.
Old May 2, 2022 | 01:19 PM
plaidside's Avatar
plaidside
If you must put a clear filter in do not use a plastic or the screw apart type in the pressure line.
On my 61, I put one in the rear line from the tank sending unit to the chassis line just in front of the rear tire.
Old May 2, 2022 | 09:52 PM
vetteman061
Thanks for the replies. This is just a temporary solution to get the car mobile and to monitor how dirty the fuel is coming from the tank.
Old May 2, 2022 | 10:30 PM
TRP_IV's Avatar
TRP_IV
If it's just temporary, can you get the proper fittings for the end of the hard line and carb (or from the fuel pump) that would allow you to plumb in a loop of rubber line and attach the filter in the rubber loop?
Old May 3, 2022 | 02:31 AM
johnnyb26's Avatar
johnnyb26
What ever you use don't use one of those cheap ones from the parts store my son did and after two weeks it leaked and burnt up his truck.
Old May 3, 2022 | 07:46 PM
toddalin's Avatar
toddalin
Mine is clear glass. I installed it on the vertical fuel line and a right angle comes off of it and feeds the Holley DP fuel line.
Bad shot but shows what's up.
Old May 3, 2022 | 07:58 PM
ghostrider20's Avatar
ghostrider20
Tom
This. Easy and out of sight. I do this with a large clear filter. Those intake mounted PF-90 filters are expensive.
Old May 3, 2022 | 08:02 PM
Nowhere Man
What is the fascination with needing a filter. If your tank is that bad where debris is going past the sock and clogging the carb filter. Then don’t you think it’s time to replace the fuel tank. They are relatively cheap and a huge safety item.
Old May 3, 2022 | 10:10 PM
TRP_IV's Avatar
TRP_IV
As vetteman061 stated early on, it's just temporary to get the car mobile and to monitor how dirty the fuel is that's coming from the tank...
Old May 3, 2022 | 10:11 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
God point...Tanks Inc. makes a nice tank. I have one of there FI Tanks since I run MSD Atomic EFI System with a return. This link should take you to the Midyear page. If not go to home and work towards the Chevy...then Corvette ..then your year Non FI. Scroll down for accessories.
https://www.tanksinc.com/index.cfm/p...rod/prd155.htm
Old May 3, 2022 | 10:54 PM
EJC22's Avatar
EJC22
I'm with Jim
Old May 4, 2022 | 11:41 AM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Flush the tank first by draining thru a paint filter in a bucket. Pour thru again if it is catching a lot of crap. Disconnect line at tank and fuel pump. Blow out with air. Rebuild fuel pump. You would be surprised what could be in it. Clear line to carb and install a new filter in carb. Good to go after that. Band-aids only last so long. Do it right the first time!
To Adding clear fuel filter
