Pitman arm removal
Old May 16, 2022 | 04:49 PM
Joemac8's Avatar
Joemac8
Default Pitman arm removal
I got the pitman arm free from the steering box with a puller. How do I get the other end off the drag link?
Old May 16, 2022 | 05:28 PM
56early's Avatar
56early
Did it backwards. take it apart opposite the way you would put it together. get a pickle fork or sharp hammer blows on the side of the tapered joint forging.
Old May 16, 2022 | 08:12 PM
Joemac8's Avatar
Joemac8
So put it back together and start beating on the small end?
Old May 16, 2022 | 09:26 PM
bauto's Avatar
bauto
you might be able to get it to split apart with just the pickle fork but without it mounted to the steering box it will be more difficult
Bob
Old May 16, 2022 | 09:30 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I would be very reluctant to start beating on thepitman arm or anything attached to it while it is on the steering box
Old May 16, 2022 | 10:48 PM
Factoid's Avatar
Factoid
The taper on the relay rod stud greater making it easier to remove. In your other thread I shared the proper order. A pickle fork will easily separate the relay rod without damaging the steering box, but you may need to replace the relay rod seal and clamp which are cheap.
Old May 16, 2022 | 10:52 PM
bauto's Avatar
bauto
A pickle fork is used every day in the real work without any Issues, you could always dig out the service manual and see what gm used back in the day
bob
Old May 17, 2022 | 08:13 AM
Joemac8's Avatar
Joemac8
I will remount the arm to the steering box, then head to town to get a pickle fork. I will then remove the arm from the drag link, then remove the front from the steering box.
Does this sound right?
Old May 17, 2022 | 08:16 AM
56early's Avatar
56early
That will work
Old May 17, 2022 | 09:15 AM
Vega$Vette's Avatar
Vega$Vette
I just did PS conversion. Used this tool that was free loaner at local parts store.
Much better than a pickle fork.
Old May 17, 2022 | 09:22 AM
Joemac8's Avatar
Joemac8
I'm stoping at NAPA to borrow a tool. I'll see if they have this instead of a piclke fork. Thanks!
Old May 17, 2022 | 11:36 AM
plaidside's Avatar
plaidside
This is what I have been using for years and does not damage the boot.
Old May 17, 2022 | 12:47 PM
DansYellow66's Avatar
DansYellow66
The couple times I’ve done this I used a puller. Tighten it and then give the arm a couple taps around the knuckle, tighten some more, couple raps and retighten. It usually pops free without much trauma after a few repetitions but I could have been lucky.
Old May 17, 2022 | 03:32 PM
56early's Avatar
56early
This tool was a dealer essential tool from Ford. I can't remember if it was the Focus or Edge or maybe both. The outer tie rods on the steering knuckle can not be separated with a pickle fork or sharp hammer blows. The tool works on your application if you are saving the boot. In my time on the floor I would just give it a hammer whack one hit usually did the trick.
Old May 17, 2022 | 04:21 PM
Joemac8's Avatar
Joemac8
I did all of that and NOTHING. I just started a rant about it. I am so damn frustrated.
UPDATE: With a neighbor’s help, it is off. All is well
Thanks to all who Responded
Old May 19, 2022 | 09:04 AM
dmtparker's Avatar
dmtparker
What year are you talking about? On my 62, you remove the cotter pin, unscrew the cap and it falls off in your hand with just a little twisting. Only note is you need to do both ends of the drag link at once .
To Pitman arm removal
