Fuel level sending unit
Old May 23, 2022 | 08:57 PM
jet-tech's Avatar
jet-tech
Default Fuel level sending unit
Who makes or sells the best reproduction fuel level sending unit for a 1966 Vette? Today I was putting gas back in my car getting ready for a break-in engine run on my newly rebuilt engine. One of the wire studs on the fuel level sending unit had pulled out and fuel was pouring out. I was able to plug it with a small bolt and siphon most of the fuel back out. My wife walks into the garage soon after and I hear those words "what's that smell" again.
Old May 23, 2022 | 10:07 PM
C2Scho's Avatar
C2Scho
It seems that most reproductions of the fuel tank sending unit for a C2 sold by vendors have problems associated with them and they well all be made by the same manufacturer in China.
My friend and Forum member bought a standard vendor reproduction and it reads 7/8 of a tank even when the tank is full up to the neck. We took it out of the tank and checked the OHM readings through the full swing of the float arm arc and the OHM readings are indeed off. Another friend of mine (also a Forum member) found a new configuration sending unit advertised as a GM Restoration unit from one of the corvette vendors. We ordered one and it OHM's out to spec so we installed it in my other friend's gas tank. I will report back here when he fills his tank and reports the levels as the tank empties of gasoline. We will see how it goes. I have copied the link to this new configuration sending unit in case you want to try it out. Both the locking cam and the rubber O ring are reproductions so those may be the Achilles Heel in the configuration. We are praying that it doesn't leak.
I have included a picture of it after we installed it in the gas tank. Good Luck with it. C.J.
1963-1967 Gas Tank Sending Unit - Corvette Parts New, Used, Reproduction. Corvette Wheels, Side Exhaust Rims (csofmdwest.com)
Old May 23, 2022 | 11:00 PM
jet-tech's Avatar
jet-tech
Thanks C2Scho, I just went to that link and it shows out of stock.
Old May 24, 2022 | 12:14 AM
jet-tech's Avatar
jet-tech
Is this unit from Zip the same as the one you noted in post #2? https://www.zip-corvette.com/63-67-g...nit-meter.html
Old May 24, 2022 | 07:26 AM
C2Scho's Avatar
C2Scho
I am sorry to hear that the link I sent you shows the sending units to be out of stock. Hopefully they will get some more in soon.
The one from Zips is definitely Chinese made and not the same. I called Zips before I ordered from the other vendor because I wanted to give the business to Zips if possible but the salesman at Zips checked and confirmed for me that the unit they sell is made in China.
The "GM Restoration Part" designation at the other vendor caught our eye and that was a big impetus for us to buy from them. If the float swing arm had not OHM'd out correctly then we likely would not have installed it. It is always better to have an original restored or rebuilt if possible. Tri Starr LLC is currently backlogged for 16 weeks and are no longer accepting any OE fuel sending units to be restored. John Wolfe and Company lost their restoration guy and no longer does them that I am aware of. At least one of our Forum members has restored his OE unit himself and has posted a nice "how to" here on the Forum.
Hope this helps. C.J.
Old May 24, 2022 | 11:28 AM
jet-tech's Avatar
jet-tech
My current fuel level sender that's in the car now is not an original unit. Im am looking for the GM Restoration Parts unit that you noted, no luck so far. Thanks
Old May 25, 2022 | 04:50 PM
2KREDVert's Avatar
2KREDVert
I tried 3 of them before I got a good one. The one I got from Zip works fine. They don't like to pass through the hole in the tank so you have to be careful and not force it too hard.
To Fuel level sending unit
