[C2] Drivetrain Issues
Old May 26, 2022 | 08:32 AM
jovo123's Avatar
jovo123
Cruising
Default Drivetrain Issues
When backing out of garage, rubbing noise from drivetrain. This happens when in reverse. After going forward, noise goes away. the car has 300 HP, automatic trans., 37,000 +/- miles
Old May 26, 2022 | 08:43 AM
Vega$Vette's Avatar
Vega$Vette
Probably the E-brake
Old May 26, 2022 | 11:43 AM
silver837's Avatar
silver837
What year is the car? Does it have drum brakes , or disk brakes or a combination of both ?
Old May 26, 2022 | 12:16 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Don’t powerglide make weird noises in reverse
Old May 26, 2022 | 12:58 PM
jovo123's Avatar
jovo123
Cruising
It's a 1963 SWC with drum brakes.
Old May 26, 2022 | 01:03 PM
larebob's Avatar
larebob
The front differential mount is stressed one way forward and opposite in reverse. If the mount is loose, the diff pinion end may move up or down enough to have the shaft rub on the E-Brake cables or something else. Might be witness marks on whatever is being rubbed.
Old May 26, 2022 | 04:45 PM
GTR1999's Avatar
GTR1999
True and the brackets were thin metal that often cracks. 63-4 use just a 7/16-14 short bolt in the first holes of the diff. This was revised to through bolts in 65. The bracket issue wasn't resolved until 69
To Drivetrain Issues
