[C2] 1967 Spark Plug Question
Old May 29, 2022 | 06:37 PM
pats67copo's Avatar
pats67copo
Default 1967 Spark Plug Question
I have a 67 327-350 and I want to do a tune up right now it has NGK XR 5 V-Power plugs and I'm trying to find out what AC plug would be correct for this motor
Thanks for any help you can give
Pat
Old May 29, 2022 | 06:42 PM
plaidside's Avatar
plaidside
R45S AC or 85 Autolite is a good plug to use.
I use the Autolite in all my cars.
Old May 29, 2022 | 06:51 PM
Powershift's Avatar
Powershift
AC 45. Available as NOS or reproduction on Ebay. One set should last MANY (many) years.............the way most of us drive these cars.
Larry
Old May 29, 2022 | 08:27 PM
pats67copo's Avatar
pats67copo
Old May 29, 2022 | 08:28 PM
pats67copo's Avatar
pats67copo
Larry
Old May 30, 2022 | 10:22 AM
SWCDuke's Avatar
SWCDuke
Unless you're having your car judged, there's no reason to use AC plugs. I don't even know who makes them. AC Delco is just a marketing outfit that contacts with the lowest bidder to manufacture parts.
Back in the day the AC 45, which was one heat range hotter than the OE 44 was more resistant to fouling, but it's long out of production and all currently available AC plugs are resistor type.
Non-resistor equivalents to the AC 45 are the NGK B4 and Denso W14-U.
Duke
Old May 30, 2022 | 01:11 PM
John BX NY's Avatar
John BX NY
I've had AC R45S (S=extended tip) in my 67 350 HP for rmany years. I wouldnt use NGK for the same reason I wouldnt use Hankook tires. It just feels wrong.
Old May 30, 2022 | 03:45 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
False sense of brand patriotism... Your AC Delcos are likely made in China while the NGKs are likely from West Virginia. Jus' sayin' time has flip-flopped loyalties on us.
Old Jun 5, 2022 | 04:18 PM
pats67copo's Avatar
pats67copo
tHANKS
To 1967 Spark Plug Question
