[C2] Dash light bulb recommendations
Old Jun 19, 2022 | 04:30 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Default Dash light bulb recommendations
I know there have been many threads on this and therefore confusion for me.
For those that have experimented with this can you please tell me the brand and bulb numbers for each socket you finally settled on so I can order the right number and amount.
I don’t care about the original green cast from the factory and don’t care about any effect on the dimmer as I will always run them at their brightest.
So, does someone have a list?
How many of each number bulbs are in the instrument cluster?
Old Jun 19, 2022 | 04:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
with a correctly restored and clean cluster stock bulbs listed in the owner's manual is plenty bright. but then again, my eyesight is still good
Old Jun 19, 2022 | 04:43 PM
68hemi's Avatar
68hemi
We’ll, mine is not so I need brighter bulbs.
Old Jun 19, 2022 | 06:14 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The only caveat I've seen is that brighter bulbs = less hours before burn-out. (Sylvania prints the approx. hours on the packaging, as I recall.) That may be fine for brake or turn signals but to take the dash out is a major undertaking; I'd rather have long life at the expense of brightness.
Old Jun 19, 2022 | 06:35 PM
L78's Avatar
L78
sounds reasonable, but I’d ask how many hours can be expected, and how many hours will most of us put on our cars going forward…
and is a brighter bulb more likely to have an early failure ?
Old Jun 19, 2022 | 07:14 PM
leif.anderson93's Avatar
leif.anderson93
Not if it's LED compared to a comparable incandescent.
Old Jun 19, 2022 | 07:54 PM
Bondo Lane's Avatar
Bondo Lane
You beat me to it. Yeah, if endurance is going to be a concern, go LED. I've seen them sold in dashboard sockets, ready to go. Never looked specifically for 'vette though.
Old Jun 19, 2022 | 08:00 PM
barkingrats
Are there any special considerations to change to LEDs or are they plug-n-play?
Old Jun 19, 2022 | 09:13 PM
leif.anderson93
Just be sure you buy dimmable lamps...no other "special" considerations.
https://www.superbrightleds.com/vehi...=607&year=1967
Old Jun 19, 2022 | 09:15 PM
Avispa's Avatar
Avispa
Only a couple of issues. In the cluster, the cigarette lighter bulb is small and needs a small bulb. 5 chip LEDs won't fit. They won't fit in the heater and radio control "bullet" either. The BRAKE and LIGHTS tattle tale sockets may be reverse polarity, so you'd need non polar or reverse polarity LEDs for either of those.
If you want to keep using regular bulbs, #1416 is good for all the cluster and clock lights. Same issue with the bullet. All that will fit in there is 1816 or 1817. 1816 for the turn signals and hi beam indicator. Cigarette lighter use #53. All of these are available from CEC Lighting, Sylvania, Eiko and a couple others. CEC's web page is great. Has tons of specs on the bulbs so you can figure out decent substitutes. I've had really good luck with ledlight.com for small LEDs. Totally redid the cluster with bright LEDs and you can SEE it at night.
Old Jun 20, 2022 | 08:12 AM
DiabolicalDave's Avatar
DiabolicalDave
Old Jun 20, 2022 | 03:32 PM
68hemi's Avatar
68hemi
OK, so what is the bottom line as in the original post questions? For those that have experimented with these what is the RIGHT brand to buy and do they sell as a package for a midyear or does some one have a list of LED numbers and how many of each needed?
Old Jun 20, 2022 | 07:56 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Contact Frankie the Fink on this forum.
Old Jun 20, 2022 | 08:05 PM
68hemi's Avatar
68hemi
Unfortunately Frankie was perminately booted off the forum and I don’t have his contact info.
Old Jun 21, 2022 | 07:51 AM
Joemac8's Avatar
Joemac8
I believe he is active on the NCRS Forum by his first and last name???
Old Jun 21, 2022 | 08:55 AM
Redbird's Avatar
Redbird
See if Frankie is on NCRS forum.
Old Jun 21, 2022 | 08:58 AM
Nowhere Man
Since he sold his 63 I have not seen him post on the NCRS forum. So I am not sure how active he really is
Old Jun 21, 2022 | 08:56 PM
Avispa's Avatar
Avispa
None of these are sold in a package. You'll have to buy the individual bulbs. The packages from the big vendors are correct replacement bulbs. You might want em brighter.
Cluster and clock illumination
https://www.ledlight.com/ba9s_2_5_wa..._led_bulb.aspx
Turn signal, radio dial lamp and high beam indicator
https://www.ledlight.com/ba9s-5-ultr...led-light.aspx
Glove box, radio and heater **** illumination, BRAKE and LIGHTS tattle tale indicators, regular bulb 1816. Available at any auto parts store.
Ignition switch lamp regular bulb 3893. Available at any auto parts store.
Cigarette lighter lamp. Regular bulb 53 or 1445. Available at any auto parts store
Old Jun 21, 2022 | 09:57 PM
vark_wso's Avatar
vark_wso
This is how I chose to configure my '66, using green illumination for entire center dash (clock, htr controls, radio) cool white elsewhere) Superbright LEDs, (’66 model year)
# where & Superbright lamp ID
8 gray-wire panel lights in cluster, BA9S-CWHP5 (cool white, all except ctr position below Hi Bm)
1 gray-wire panel light in cluster, position below Hi Bm, BA9S-W4-90-12VAC (still too bright! Wish I had put a single LED here)
3 gray-wire clock + htr control (must trim bayonet), BA9S-GHP5 (green in clock + htr control illum)
3 BA9S-W-120 single LED, white, for cigarette ltr, glove box illum & ign switch illum
1 BA9S-G-120 single LED, green, for radio illum
3 1142-CW12-G (12 LEDs, cool white globe) for courtesy & floor illum lamps
Did not do: turn signals, brake warning, h/lamp warning, or Hi beam indicator lamps
Did not do: any external bulbs (h/l, turn, stop, park, brake, license illum, etc.)
To Dash light bulb recommendations
