carb replacement
Old Jun 25, 2022 | 12:44 PM
VinceP's Avatar
VinceP
Default carb replacement
I have a 1963 swc 300 hp I am trouble with the stock carb I called around to see about someone to rebuilt it.they want $300 I though that was hi
I was wondering what would be a good replacement carb that would fit the manifold an fit the stock aircleaner thanks Vince
Old Jun 25, 2022 | 01:44 PM
TJsBeer's Avatar
TJsBeer
I bought a 4160 direct from Holley.
Worked perfect out of the box with minimal adjustments including dwell and timing.
Old Jun 25, 2022 | 03:01 PM
rick charles's Avatar
rick charles
Default Carb.
If It Is The Org. ( 3461 S ) Spend The Money ,,,,,,,,,,,,,,,,,,,,,,,
Old Jun 25, 2022 | 03:12 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Post some photos of the carb and any numbering stamps on it. If it's a '63 Corvette carb then it's probably worth getting rebuilt; you're going to spend 2x that for a new replacement.
Old Jun 25, 2022 | 04:10 PM
leif.anderson93's Avatar
leif.anderson93
If it is truly the original carb, spending the $300 for a proper rebuild to factory specs is the correct decision. Chump change in the grand scheme of things.
Old Jun 25, 2022 | 10:49 PM
mblake101's Avatar
mblake101
A 3461s Carter AFB is a high value carb and correct for both the 300 and 340 hp 63’s. If yours does not have that number and has a stock intake, a AFB 3721 is a lessor expensive replacement almost equal performance. If you do have a 3461s, have it refurbished. It will be worth it.
Old Jun 26, 2022 | 07:36 AM
R66's Avatar
R66
Don't know for sure, but I don't think your 63 air cleaner will fit on a new Holley or Edlebrock. A $300 rebuild will save you a couple of hundred there.
Old Jun 26, 2022 | 12:57 PM
SWCDuke's Avatar
SWCDuke
Give us some detail on why you think the carb needs rebuilding. How is it misbehaving? The AFB is pretty reliable and trouble proof. The biggest problem is the choke system, mainly the choke vacuum break piston getting dirty and sticky, so choke operation is impaired. They are pretty simple to rebuild, and the procedure is in your 1963 Corvette Shop Manual. When they get over 100K miles the throttle shaft bores are usually worn enough that the idle speed is inconsistent. At that point you need a pro with plenty of experience who can rebush the throttle shaft bores.
For those of you who don't know the Holley bolt pattern is different that the AFB, and the air horn is different diameter, so no Holley is a bolt on to an engine originally equipped with an AFB nor is an Edelbrock "AFB" combatible due to a different air horn diameter. I'm not sure about the bolt pattern.
In almost all cases one is better off doing a full restoration of an AFB rather than coming up with some Mickey Mouse alterantive.
Duke
To carb replacement
