[C1] Door Striker
Old Jun 25, 2022 | 04:09 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Door Striker
What is the best way to remove the door striker on a '60? The screws won't budge.
Old Jun 25, 2022 | 05:44 PM
old60c1's Avatar
old60c1
Can you remove the door panel and get at those screws from behind with some spray? Just a thought.
Old Jun 25, 2022 | 06:46 PM
Captain Bud
I'm talking about the striker plate not the lock in the door.
Old Jun 25, 2022 | 06:57 PM
old60c1's Avatar
old60c1
Oh my God can you ever forgive me?
Old Jun 25, 2022 | 09:21 PM
1963conv's Avatar
1963conv
Theres a tool for it, an impact driven screwdriver with a few different tips. They sell at harbor freight or other tool stores. Its a hammer shock type device that would break the screw loose. Go easy at first. It should do the trick.
Old Jun 26, 2022 | 01:35 PM
C.T.'s Avatar
C.T.
Soak the screws periodically (PB Blaster or equivalent), and remember you're hammering on fiberglass. This worked on mine, and they were really frozen.
Old Jun 26, 2022 | 04:24 PM
Captain Bud
I can squirt PB Blaster on the screws but I doubt the capillary action would make it to the threads.
Old Jun 26, 2022 | 06:11 PM
Ken Sungela's Avatar
Ken Sungela
Other option to an impact screwdriver is to put a larger than normal philips head screwdriver on the screws then tap/hit the end of the screw driver. You should be able to hit it pretty hard without damaging anything. Then put a vice on the shaft of the screwdriver and push on the end with your body weight (so it doesn't slip in the screw) and turn on the vice grip. Also, If you have a small can of WD40 or the like, you could possibly squirt from the back after removing the gas tank cover.
Old Jun 26, 2022 | 08:39 PM
thoyer's Avatar
thoyer
Many battery powered drills these days have an impact setting. You might want to try that. I have a couple Milwaukee 18v drills and have had success using the impact setting to loosen things that I couldn't with a regular screwdriver. Also (without going out to the shop to check) I believe the screw heads are for a #3 phillips - make sure you are using the correct tip.
Another trick that works sometimes is to tighten the screw first. May break the threads loose. Many screwdrivers have a hex on the shaft you can put a wrench on for additional leverage.
I don't remember if you can see the backside of the striker if you remove the seat - if so maybe you can get some PB blaster on the back side.
Tom
Old Jun 26, 2022 | 11:11 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I tried all of the above on mine and if you saw how my screws were corrosion welded to the nutplate, you could see why none worked. I removed the wheel and line sighted to the wheel well right behind that striker. Cut a 3” x 5” square out with my jigsaw and a thin blade and then you have access to the backside. I then bonded the fg piece back in, swept in bondo to fill the sawcut. Can’t even tell it.
if you want pics of my project, I’ll post them here. Good luck!
Old May 24, 2023 | 11:38 PM
yaww's Avatar
yaww
I managed to get 2 of them out today, thanks for the ideas. I worked from the door side. They first loosened up only little, and then got stuck. I could not even screw them back in. I used WD40 from the little opening, an impact driver with a large bit and a strong heat gun (covering the surroundings). One Phillips bit even broke, fortunately screw heads are holding. Tomorrow I will try PB and more heat.
Impact driver: https://amzn.to/432y1E8
Bits: https://amzn.to/42aDhV0
Old May 25, 2023 | 06:51 AM
59BlueSilver
According to tests, the best penetrating oil to use is a 50/50 mix of ATF and acetone.
Old May 25, 2023 | 06:52 AM
Tuco888's Avatar
Tuco888
I have the exact same problem with a 61 I’m restoring. I’ve tried everything listed here and more. They won’t budge even with an impact.
I’ve decided to leave them and mask them off before paint. I don’t want to risk breaking the bolt or nut plate or the fiberglass.
Old May 25, 2023 | 08:21 AM
scowser's Avatar
scowser
It is a bit tricky but you can drill out the bolts and install new nut plates. You can fish the new plates through the big round holes in the floor of the gas tank compartment. The driver door is relatively easy as you can do it through the hole where the gas filler hose goes. I've done it on my '61. I assume you '60 is the same.
I spoke too fast. You can't fish the nut plates through the holes in the bottom of the gas tank compartment. But I did get the one installed on the driver side by fishing it through the hole where the gas filler hose goes.
Apologies.
Old May 25, 2023 | 11:56 AM
John S 1961's Avatar
John S 1961
I like acetone, power steering fluid and marvel mystery oil. Ps fluid is mostly paraffins.
Old May 25, 2023 | 01:00 PM
yaww's Avatar
yaww
I am happy to inform that the 3rd screw is also out. Between PB, WD40, heat gun, impact drill; I finally attacked the last one with a vise-grip as it was a few millimeters out and I was able to grip the head. Those screws are seriously sturdy, I guess steel.
Old May 25, 2023 | 01:12 PM
Plasticman's Avatar
Plasticman
You can also use some valve lapping compound for a "better" grip on the screw bit recess, so it doesn't round out on you.
Plasticman
To Door Striker
