Help with window date code
Old Jul 7, 2022 | 01:24 PM
slwhittenburg's Avatar
slwhittenburg
Default Help with window date code
If looking at what is stated as a 64 aux hardtop rear window. Image is attached. It appears to a D in the lower left and a G in the upper right. This doesn't make sense from the postings on date codes I can find. Can someone tell me the month and year? Thanks.
aux hardtop date code
Old Jul 7, 2022 | 03:50 PM
Powershift's Avatar
Powershift
According to NCRS Judging Manuals, D and G represent April 1967 date code. 1963-64 model years used numbers and not letters for date coding.
Larry
Old Jul 7, 2022 | 09:13 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
I don't mean to steal the thread, but rather join-in with sl... I just looked at my purportedly '64 hardtop that has the following stamping:
looks same as slwhittenburg's, but minus the ghostly "D". Also, my car was built in Nov '63, but the hardtop does not have the 'notch' in it. So, would our two hardtops actually be '64, or not? Thank you for letting me jump in here
Old Jul 8, 2022 | 05:44 AM
63driver's Avatar
63driver
The Auxiliary Hardtop for 1963-1964 models had three distinct designs.
Design One: At the startup of 1963 production the auxiliary hardtop had a notch cut in the bottom, each side, to give greater clearance above the door. This design was present until approximately March 1963.
Design Two: For cars built in approximately April, May and June 1963 the notch in the auxiliary hardtop is not present.
Design three: For cars built approximately near the end of June 1963 until the end of 1963 production and all 1964 production the notch in the auxiliary hardtop is not present and rear window reinforcing brackets are present at the upper center and lower center of the rear Plexiglas.
To Help with window date code
