I need a new 8" damper for my built 406sbc that's internally balanced. I see many variations for sale on Summitt, Jegs & ebay so is there something in particular to look for or anything to avoid?
FWIW..... Did a reputable shop build the engine? If so, talk with them. An important part such as this, I would never buy it off Ebay unless it is a WELL know performance supplier. Dennis
I'm not sure you could call me a 'reputable shop', but I built it. And I'd never claim to be an expert at anything, much less building performance motors but I do have some experience.
I don’t think you could wrong with a Fluidampr been around for years track proven & there 360 degreed, pricey but this is a area u don’t want to go cheap on..
Good Luck
Chalie
Pricey is right! Not going cheap but this is just a street car so can't see spending that much for a good quality damper.
Quality for dampers is all over the board now. Lots of cheap inferior stuff out there. Pay a bit more and get an SFI one even if it’s “not a race car”.
The quality control is worth it.
You don't mention why you need a new balancer. Can you clarify what the problem is?
If the only problem is that the rubber isolator has deteriorated, one option would be to have your existing balancer rebuilt by a specialist service such as Damper Doctor.
Also, are you looking for the "big" small block balancer that is 8" in diameter and approximately 1-11/16" thick? The 1962-1968 versions had the timing mark almost lined up with the keyway, but the starting in 1969, the timing mark was moved several degrees.
The service replacement GM part number has gone through about eight changes, but I believe the most recent part number is 19260269 and is still available from GM. I'm not sure what it has in terms of the timing mark.
I had my Camaro at the truck earlier this year for the first time in 25 years. And it showed… I spun the balancer and it pushed off about 1/2” as well. I ordered an SFI balancer which is what I would recommend. No more spun balancers. I think the ProBond was the one I got?
Are you sure you want an Internal Balancer? A 400 is normally externally balanced. Damper Dudes or Damper Doctor near Redding CA can rebuild any damper for you to like new condition.
Mark, it's an internally balanced rotating assembly and the damper can't be repaired according to Damper Dudes.
Wow, that certainly looks like a failure. You will need new parts. I wish my 400 was internally balanced but I used the parts I had and I am running the original 400 crank turned .010 under so mine will be externally balanced. I like your set up better as you can run the same parts as the original 327 for balancer and flywheel.
Yes, flywheel and starter. But it was probably a mistake to use my old damper. It was undoubtedly not the recommended press fit as Robert61 noted and thus failed catastrophically. I've mic'ed the nose of the crank and it appears to not be too badly damaged. It's round with no eccentricity or taper but I cannot find precise specs for it. I find anything from 1.245 to 1.249. I'll have a new damper in a few days and I'll know if it's a good press fit or not.
You might put a mic on your snout and see how large it measures. Sincei it is internally balanced I am guessing Scat or Eagle? It would be important to know the size before installing a new balancer.
It's 1.245...too small for most balancers I'm finding that are nominally that size as well. In all the reading I'm doing...and it's a lot so far, I find that Scat is known for undersize noses. They actually make dampers as well so I'm trying to get the specs for theirs.
Update: A new damper arrived today and using calipers, it appears to measure 1.2425". I don't have inside mics that size so I'm going to a friend's machine shop to re-measure but if that's close to accurate, I'll have sufficient interference for a good press fit. That's a big relief!
Update #2: The new damper mics out at 1.245 so that doesn't provide any interference. Still searching for damper and crank specs and may have to order a custom damper. And I was mistaken about the brand of crank...it's an Eagle.
I see you have about .003 extra clearance. When you slide it on how does it feel? Is there any movement or walk when you try to move it side to side or up and down. If it feels tight, no detectable movement, I think I would bolt it and move on. I am thinking your broken damper went on very tight?
Edit, sorry I read the measurements wrong. Both damper and snout are 1.245. I think I would run it.
Did you mic the crank with a micrometer or calipers. This is where everything needs to be measured with a mic. As I told you earlier ATI makes an undersized hub you have to fit to size. You can buy a new damper from them pricey or buy a used one on eBay and change the hub. There are occasionally dampers listed with a bad hub.
Mark I’m reading the crank and damper are both 1.245. So he doesn’t really have clearance or press.
