voltage issue
Old Jul 14, 2022 | 05:46 PM
radiomanpo2's Avatar
radiomanpo2
8th Gear
Default voltage issue
My voltage guage is pegged. battery is 12.8. Voltage is 16 from regulator. Is regulator the problem? 1962
Old Jul 14, 2022 | 09:42 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
I don't know what you mean by 16 from regulator but the only thing on a car that can make 16 volts is the alternator and the roll of the regulator is to hold it to 14.2 volts, so I'd be sniffing at the regulator.
Dan
Old Jul 15, 2022 | 07:00 AM
C2Dude's Avatar
C2Dude
The mechanical regulator on my 66 failed the first time I started her this season, was permitting 16+ volt overcharging. Bought a new VR at Napa with no change. Spent a week troubleshooting every ground and circuit. In the end I picked up another solid state VR and all was well. The new mechanical unit was bad out of the box. No going back to mechanical VR for me.
Old Jul 15, 2022 | 08:41 AM
plaidside's Avatar
plaidside
Is your car a 1962? When the engine is above 1,000 RPM what is the battery voltage at the battery and at the generator 'B' terminal.
When you say "from the regulator", are you testing at the battery terminal of the regulator?
I would make sure you have a good ground at the regulator, you can run a test lead from the battery negative to the case.
To voltage issue
