67 Brake Distribution switch bracket
Old Jul 15, 2022 | 01:55 PM
Joemac8's Avatar
Joemac8
Default 67 Brake Distribution switch bracket
On my 67 L79 I want to change to power brakes. In examining what I have now, the break distribution switch is attached to the car via a stamped metal bracket.
The bracket is visible here, bolted to the top of the distribution switch.
It occurs to me that when I install the power booster, I will have to move the brake lines forward. This in turn necessitates moving the brake distribution switch. At that point the bracket holding the switch will be too short. I checked the AIM and repair manual and do not see this bracket. I would like to get a longer bracket to accommodate the forward moved distribution switch. Can anyone enlighten me as to where to get one or even if they exist?
Old Jul 15, 2022 | 02:28 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
For '67, according to the AIM, bracket #3910797 was used for all brake installations except J56. (UPC 5, B1, UPC J50, A1) . Because it connects to the bolt(s?) of the master cylinder it doesn't matter power or not.
(The circle 6 call-out was a changed part number on 8/22/66.)
Old Jul 15, 2022 | 02:48 PM
leif.anderson93's Avatar
leif.anderson93
The switch and bracket will move forward with the master cylinder...as per the AIM.
Old Jul 15, 2022 | 03:31 PM
Joemac8's Avatar
Joemac8
Guys, THANK YOU!!!
To 67 Brake Distribution switch bracket
