[C2] '67 Interior Door Latch
Old Jul 23, 2022 | 03:54 PM
Good'nuff's Avatar
Good'nuff
Default '67 Interior Door Latch
I took the whole door apart to replace the latch with a new one. After installing, I checked it to see that it functioned correctly. It did.
Then reinstalled door panel and it does Not work!
Don't know what I did or didn't do... to end up at that frustration point where you are ready to take it out for spin - knowing "she's all better now"... but NO.
Old Aug 4, 2022 | 08:56 PM
red zed's Avatar
red zed
Assuming you mean the spherical **** won't unlatch the door from the inside, I've been through this also. Some folks bend the rod to shorten it, others drill a new hole in the plate of the "remote control assembly" as it's referred to in the assembly manual, sheet K7.
Here's an old thread with a pic:
https://www.corvetteforum.com/forums...om-inside.html
