Need new rag joint
Old Jul 30, 2022 | 08:58 AM
Bdeliman's Avatar
Bdeliman
Default Need new rag joint
I need a new rag joint for a non power steering 65. I see products from Ididit for an installtion kit for original harness, but it includes wires. Not sure the reason for the wires for a mechanical part that goes between the steering box and the steering column. Can someone point me to a new part or educate me on this ?
Bill
Old Jul 30, 2022 | 09:05 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
do you have a standard column or tele? if standard column I would be on the look out for NOS ones. they show up on Ebay and on here from time to time
Old Jul 30, 2022 | 10:03 AM
R66's Avatar
R66
Not sure what the wires are for, but the original rag joints had a brass / copper strip between the upper and lower parts of the rag joint to complete the ground in the steering shaft. I believe this is needed for electrical continuity within the steering shaft. Maybe some of the professionals can confirm or deny my assumption.
Ron
Old Jul 30, 2022 | 10:29 AM
GTR1999's Avatar
GTR1999
Bill
It doesn't matter if it's manual or PS, same rag was used. If you have a tele column, then you have a better chance of hitting the lottery than finding a NOS one. If standard steering NOS ones do show up, expect to pay $300+ for them. I don't think I have any left for std 63-66's, 67-e69 I do.
If you go with the current, new imported $50 rags or kits, the material is not as rigid, if you are concerned about NCRS they won't be close. I don't care for any of the new ones, including Borgeson's version.
Good luck, if yours is ripped now, don't drive the car. A u-joint will work, flaming river sells them. The originals were grounded across the rag halves, but the strap broke a lot of times, so by 72 they were wire mesh grounded which worked much better.
Old Jul 30, 2022 | 11:22 AM
Duck916's Avatar
Duck916
I believe that the horn will not work if there's no continuity between the upper and lower sections.
Old Jul 30, 2022 | 11:49 AM
Nowhere Man
Correct
Old Jul 30, 2022 | 12:11 PM
Bdeliman's Avatar
Bdeliman
It is not a tele
Old Jul 30, 2022 | 01:21 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Both my 65 and 66 have tele columns. Fr now all is well I am hoping that some time soon someone will come up with the right rubber to repo these things again. In the mean time I guess the only alternative is a U joint. Do these need to be grounded for correct horn operation or are they self grounding?
Old Jul 30, 2022 | 01:22 PM
Nowhere Man
they need the ground
Old Jul 30, 2022 | 01:32 PM
Bdeliman's Avatar
Bdeliman
Will this work? What exactly is this? Is it a complete rag joint and wires, or is it a rebuild kit for the old joint. My old joint didn't have wires and my car is not NCRS.
https://www.topflightautomotive.com/...ginal-harness/
Bill
Old Jul 30, 2022 | 01:38 PM
Nowhere Man
your buying more then you need.
Old Jul 30, 2022 | 03:33 PM
Bdeliman's Avatar
Bdeliman
I don't have an old joint to rebuild. I threw it away when I started the frame off 12 years ago, never thinking it would be hard to get a new one. So can you point me to one that will work for me ?
Bill
Old Jul 30, 2022 | 03:35 PM
GTR1999's Avatar
GTR1999
That's a borgeson rag- thinner material and set screws used, not as good as OEM.
Old Jul 30, 2022 | 03:37 PM
GTR1999's Avatar
GTR1999
The ground strap completed the circuit from the steering column to the frame, however your horn may still work if it grounds elsewhere. U-joints are conductive so they're grounded once installed.
Old Jul 30, 2022 | 05:43 PM
Skenn1977's Avatar
Skenn1977
At the risk of ridicule on what I did or should've done (newbie still learning), I recently had my rag joint rebuilt on a recently acquired '65. It's the standard coupler and I believe my guy uses the rag component from a new kit and uses the original coupler components. Before and after pictures.
Old Jul 30, 2022 | 10:36 PM
smacota1's Avatar
smacota1
I posted this a few days ago. Not mine, but if you need one this will work.
https://www.ebay.com/itm/155067888089
Not cheap but neither is a C2.
I put a NOS on my car a couple years ago and since have bought two more NOS. I am sure my wife will throw them away when I an gone but until then I will keep on packratting!
Found a few more...........
https://www.ebay.com/itm/20404042021....c101113.m2108
https://www.ebay.com/itm/11546058375...MAAOSw8jpiyyNr
https://www.ebay.com/itm/28487372659...kAAOSwssliuhg5
Old Jul 31, 2022 | 03:16 PM
68hemi's Avatar
68hemi
Your old rag joint LOOKED fine? Was there a problem with it? If not then you traded a good factory one for a lower quality part.
To Need new rag joint
Old Jul 31, 2022 | 05:37 PM
Skenn1977's Avatar
Skenn1977
It was a little sloppy, not sure if it was this component or the overall steering refresh but it's tighter now. Didn't drive bad before, but a little better now.
Old Jul 31, 2022 | 07:57 PM
Bdeliman's Avatar
Bdeliman
Can anyone give me alternatives to the rag joint. Someone mentioned a U joint.
Old Jul 31, 2022 | 08:38 PM
bauto's Avatar
bauto
I sent you a pm that i will have a restored one for sale the first part of sept if interested
Bob
