glue remover
I removed the old carpet and padding and found this mess.
after scraping the worse of the fuzzies from the floor, I sprayed the remaining dried up glue with RAPID REMOVER and let it sit about a minute. the old glue cleaned up nicely with a gasket scraper and a wire brush. warning, RAPID REMOVER is flammable and a respirator should probably be worn. use care when using. I get RAPID REMOVER from amazon.
