63 327 push rods
Old Aug 21, 2022 | 11:25 PM
TRIPOWERRAT's Avatar
TRIPOWERRAT
3rd Gear
Default 63 327 push rods
I have a 63 327 converting from solid lifter to hydraulic. Is the stock push rod the same for both? If not, what spec should I order.
Thanks for your help!
Mike
Old Aug 22, 2022 | 08:41 AM
Con's Avatar
Con
I bent a couple and replaced with JEGS 7.800 in. Long Pushrods for Small Block Chevy 262-400 V8 in a 64 327/300 hydraulic lifters.
Old Aug 22, 2022 | 09:03 AM
mapman's Avatar
mapman
Mike
Mike
Before you do this conversion, do a web search on "SBC lifter failure" or "wiped camshaft". Lots of folks reporting poor quality flat tappet lifters wiping camshafts and sending debris into engines.
Mapman
Old Aug 22, 2022 | 09:16 AM
Robert61's Avatar
Robert61
As long as you are using flat tappets the push rods are the same. I would highly recommend GM performance lifters. You'll pay more but you know what you have.
Old Aug 22, 2022 | 11:22 AM
Vega$Vette's Avatar
Vega$Vette
Mike
Many variables in an engine build can affect pushrod length.
The only correct way is to measure and buy the correct length pushrods.
To 63 327 push rods
