59 front trim frame
Old Aug 23, 2022 | 12:49 PM
Anovib's Avatar
Anovib
Default 59 front trim frame
Is it possible to remove the front grill frame without dropping the bumpers or pulling the shark teeth if so how
Old Aug 23, 2022 | 01:15 PM
thoyer's Avatar
thoyer
If you are referring to the chrome trim above and below the grill teeth - yes. They have studs that go thru the fiberglass. Remove the nuts and they should come off.
Easier to do this with the grill bar removed though.....
Tom
Old Aug 23, 2022 | 01:34 PM
Hermn59's Avatar
Hermn59
Tom
And with the hood removed.
Old Aug 23, 2022 | 09:31 PM
Anovib's Avatar
Anovib
well I learned a few things here. You need small hands. And Be aware that your working on a 60yo car
the wax and dirt build up over the years ultimately turns into concrete behind the chrome. That or back in the day they used superglue as a wax
i almost gave up but you all kept me going.
thanks for the help
Old Aug 23, 2022 | 09:37 PM
Hermn59's Avatar
Hermn59
Nice work, that is impressive! My mitts do not fit between the teeth well. At minimum, I would have had to remove a few teeth.
To 59 front trim frame
