Pipe Dope?
Old Aug 28, 2022 | 06:45 PM
Joemac8's Avatar
Joemac8
Default Pipe Dope?
I will be installing an intake manifold vacuum fitting on my 67 L79 when I complete the installation of adding power brakes. My question is do I use pipe dope on the fitting? I know not to use teflon tape. Just wondering if the fitting goes in 'raw" or if I add something to eliminate leaks?
Old Aug 28, 2022 | 06:50 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Either the pipe dope or tape will work if you use a little bit of it. But it is a NPT fitting and only is seeing air
Old Aug 28, 2022 | 07:17 PM
Powershift's Avatar
Powershift
Never seize or a pipe dope with teflon.
Larry
Old Aug 28, 2022 | 10:04 PM
pop23235's Avatar
pop23235
Larry
Steel and aluminum will seize. Never-seize delays this.
To Pipe Dope?
