[C1] Dual four Help
Old Aug 31, 2022 | 07:00 PM
Bigguyinmo's Avatar
Bigguyinmo
Default Dual four Help
I have a 1957 245hp dual four. The 283 is rebuilt and completely stock. I removed the intake manifold to replace the gaskets , my plugs where oil fouled and I suspected it was drawing oil into the intake runners.
the intake gaskets definitely needed changed.
I get it back together and now it is running very lean on the main jets. It does idle smoothly but at about 1500 rpm it has a rough idle and the engine is running hot. We pulled the plugs and they indicate lean.
I tried an experiment, I left the throttle closed on the rear carb and open the front carburetor. It still is leaning out.
the WCFB’s are correct ‘57 units.
metering rods are 1350
main jets .935
secondary jets .053
any ideas on what could be creating this lean condition?
Old Aug 31, 2022 | 07:11 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
Just a question or two. How are you assessing the lean condition? Do you have a narrow or wide-band A/F analyzer?
Show us a picture of the "lean" spark plug. Retrace your steps on the teardown and reassembly. At 1,500 rpms you are probably no longer operating on the idle circuit.
Your jetting (primary and secondary) is on the money.
You had to pull the distributor when you replaced the gaskets. Did you reestablish the correct timing on the engine?
Old Aug 31, 2022 | 08:35 PM
thoyer's Avatar
thoyer
Sounds like you need to revisit the timing. Retarded timing will do this.............
Also look for vacuum leaks.
Tom
Old Aug 31, 2022 | 09:15 PM
drainbrain's Avatar
drainbrain
Default carbs
56 and early 57 carbs have idle air adjustment
on the driver side in carb base. Close it if there.
Other than that its timing or perhaps a vac leak.
To Dual four Help
