“Bucking” C2
Old Oct 8, 2022 | 08:15 AM
Jroger's Avatar
Jroger
Cruising
Default “Bucking” C2
I have a ‘63 with a 327ci/300hp engine and a Carter AFB carburetor. I’m having an issue with it “bucking” when I try to slowly accelerate in first or second gear. I have adjusted the carburetor, checked all the plugs and wiring, reset the timing but nothing has helped. Any ideas on what the problem is?
Old Oct 8, 2022 | 08:30 AM
leif.anderson93's Avatar
leif.anderson93
Did this problem just start? Did you do anything to the car prior to this problem starting? Need a bit more recent history to help out.
Old Oct 8, 2022 | 09:02 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
One remote, but possible, cause would be a failing Ignition Coil.......
Old Oct 8, 2022 | 09:18 AM
Vega$Vette's Avatar
Vega$Vette
Perhaps it's the way you are driving the car. Need to slip the clutch at very low speeds in 1st to keep the revs up. At what rpm are you trying to accelerate in 2nd when the bucking occurs?
Old Oct 8, 2022 | 09:27 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
a 300 hp motor will never have that problem at low speed if the OEM cam is in place.
Old Oct 8, 2022 | 09:44 AM
Tom Austin's Avatar
Tom Austin
I'm with Leif . . . let's start here before we all jump to conclusions, shall we???
Old Oct 8, 2022 | 10:34 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
This doesn't sound right to me. The engine shouldn't buck at any speed. My '63 300 HP Vette never did. And even my solid lifter FI '60 takes off smoothly every single time.
Old Oct 8, 2022 | 10:38 AM
Tampa Jerry's Avatar
Tampa Jerry
It can be a bad or cracked spark plug, dirty plugs, old or loose spark plug wires, bad coil or condenser, rotor, cap, points, bad or old gas, clogged fuel system at the tank or filter, fuel pump ready to give it up, dirty carb or misadjusted choke or carb accelerator pump, trash in the carb, vacuum leak. It would be best to determine if it's fuel or ignition related and follow up. Good luck. Jerry
Old Oct 8, 2022 | 02:49 PM
DansYellow66's Avatar
DansYellow66
I too have a hard time imagining a 327/300 motor bucking or trailer hitching. I think I would look inside the distributor to see if some one installed real light advance springs allowing the weights to cycle in and out at idle speed. Also check that axial play in the distributor isn’t excessive. But still sounds strange.
Old Oct 8, 2022 | 03:40 PM
Factoid's Avatar
Factoid
When you set the timing, did you just check base or did you also check total timing and vacuum advance?
Old Oct 8, 2022 | 04:16 PM
Jroger's Avatar
Jroger
Cruising
Default Not a new issue
I purchased this ‘63 in an online auction and it was doing this bucking from the start. The dealer must have grout it had a carburetor issue since it came with a new one installed and another in a box. From the replies it appears I have a lot of possibilities to check. I’m far from an expert mechanic!
Old Oct 8, 2022 | 04:37 PM
Nowhere Man
I would start with finding the correct carb and have it rebuilt by a person who knows what they are doing then go though the dist and make sure it’s up to OEM spec.
Old Oct 8, 2022 | 04:44 PM
Jroger's Avatar
Jroger
Cruising
Default Driving info
On the driving question the bucking occurs when I attempt to slowly accelerate to 2K to 2.5K rpms to shift into 2nd or 3rd. If I quickly accelerate through the gears there is no problem -except for dirty looks from neighbors
Old Oct 8, 2022 | 04:49 PM
Nowhere Man
Look for the tuning paper written by SWCDUKE.
Old Oct 8, 2022 | 04:55 PM
Tom Austin's Avatar
Tom Austin
Well . . . that's not the answer I was looking for - but, we can work with it!
Question - can you tell if your car has new plug wires?
Let me tell you why I ask! A few years ago I did a complete tune up of my L79 - new plugs, new wires, new cap and new vacuum advance. After that tune up, my car exhibited the same "bucking" (aka "trailer hitching") at very low, steady speeds in 1st and 2nd gear just like you describe. It ran great at higher speeds and on the highway! I chased that problem for almost 18 months . . . we checked timing and advance multiple times and everything else we could think of without correcting the problem. One day I decided to pull the plugs and check them, and ever considered switching to another plug. That's when I found the problem!!! Apparently, when I installed the new plug wires, I didn't "snap" them all the way onto the end of the plugs! They were on there, but they weren't really "on there"! In hindsight, I believe that it was really tough for this old dude to reach over the fenders, way down into the engine compartment, and exert enough force to "snap" those new, really tight wires on all the way. I solved the problem with the help of a rachet . . . holding the tool in my left hand and putting the square end on the plug wire gave me enough leverage to snap the wires that last little bit! Problem solved - my car runs like a Swiss watch now!
It could be as simple as a bad plug wire connection!
Tom
Old Oct 8, 2022 | 05:09 PM
6T7L71CPE's Avatar
6T7L71CPE
It might help if you post good pictures of your engine from all sides. Something may stand out that may be causing the problem.
Old Oct 8, 2022 | 05:46 PM
DansYellow66
Tom
With the additional description I think this is a good possibility. Most bad plug wires I have experienced caused missing/surging under steady throttle and light acceleration. Yet it would accelerate cleanly with full throttle. Something with voltage and system resistance under different engine load conditions I guess.
To “Bucking” C2
Old Oct 8, 2022 | 07:10 PM
kts1962's Avatar
kts1962
Originally Posted by Nowhere Man;[url=tel:1605767622
1605767622[/url]]Look for the tuning paper written by SWCDUKE.
the best version of this is the newest version where Lars and SWCDuke collaborated.
mail Lars and he has always happily sent a copy
I think this is his contact info:
To request articles, just drop me an e-mail to:
V8FastCars@msn.com
Old Oct 8, 2022 | 07:13 PM
Factoid's Avatar
Factoid
Try these.
https://www.corvetteforum.com/forums...tributors.html
Old Oct 8, 2022 | 07:38 PM
tuxnharley's Avatar
tuxnharley
Too much vacuum advance at low rpm?
