POWER WINDOW CONVERSION Help
Old Oct 26, 2022 | 07:17 PM
D67's Avatar
D67
Default POWER WINDOW CONVERSION Help
Installing power windows in my 67 conv, I am having trouble removing the window from the door. The vent window frame is out and the side window is free from the channel and lose, but there is an L shaped bracket at each end of the bottem of the window that will not pass thru the window opening in the door. They appear to be stops that limit the upward travel of the window. The instructions do not show the L brackets. Do they have to be removed to get the window out.
Old Oct 26, 2022 | 07:55 PM
c2performance's Avatar
c2performance
Default windows
Yes they have to be removed. The rear one should be a Philips screw and the front one will be a 7/16's nut. If I recall right. Tom
