Big block
Old Oct 28, 2022 | 06:25 PM
Little67red's Avatar
Little67red
Default Big block
Is the big block frame different than the small block. What would you have to change going from small block to big block.
Old Oct 28, 2022 | 06:36 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Frames are the same. The AIM clearly list everything needed to take a base 300 3 speed to a BB
DansYellow66's Avatar
DansYellow66
From 65 on the BB and SB frame was the same. Prior to that - no BB cars. You can do a search for what made a BB car - there are literally hundreds of prior posts on the subject.
Old Oct 28, 2022 | 07:00 PM
Factoid's Avatar
Factoid
Do you simply want to put a big block in your small block car or do you want it to look like the car came from GM with a big block?
VERY big difference.
Old Oct 28, 2022 | 07:16 PM
Vette5311's Avatar
Vette5311
Early C2 frames did not have clearance for BB balance damper.
Old Oct 28, 2022 | 08:13 PM
Little67red
My car is a 67 coupe. I was told small block cars didn’t have room for the bb damper. I am trying to make it look like it came from the factory.
Old Oct 28, 2022 | 08:16 PM
Vette5311's Avatar
Vette5311
Easy to tell, there is a 1/2 moon recess in the center rear top, right in front of the crankshaft centerline, front crossmember.
Nowhere Man
nope. the frame is not your problem.
Old Oct 28, 2022 | 08:21 PM
Little67red
What is my problem
Old Oct 28, 2022 | 08:23 PM
Nowhere Man
Originally Posted by Little67red
What is my problem
several thousands of dollars of needed parts to make it right
Old Oct 28, 2022 | 09:21 PM
Little67red
Like what parts are you talking about.
Old Oct 28, 2022 | 09:52 PM
Nowhere Man
do you have the AIM?
Old Oct 29, 2022 | 12:07 AM
Factoid's Avatar
Factoid
Radiator, fan shroud, hood, hood prop, engine, z-bar, throttle linkage, front springs, shocks, rear sway bar, differential u-joint caps, potentially the instrument cluster, and I’m sure I’m missing some things.
Old Oct 29, 2022 | 08:48 AM
Tampa Jerry's Avatar
Tampa Jerry
Don't forget the fuel line. Jerry
Old Oct 29, 2022 | 09:46 AM
Nowhere Man
you are forgetting the engine itself, all the brackets, pulleys, and linkage. Factoid if he has a L79 I/C and cloning the L36/L68 it uses the same I/C
Old Oct 29, 2022 | 10:04 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
To look like a BB prepare for a big
job, and a expensive one. There are a
lot of big and little parts involved.
Good luck
Old Oct 29, 2022 | 10:09 AM
leif.anderson93's Avatar
leif.anderson93
Might want to read this current thread. Lot of answers to your question.
https://www.corvetteforum.com/forums...lock-66-a.html
To Big block
Old Oct 29, 2022 | 11:13 AM
Gavin65's Avatar
Gavin65
This is not an inexpensive proposition, im in the process of doing very much the same thing to my 65, however I’m not just swapping an engine I also will be upgrading the transmission and full front and rear suspension, I currently have roughly a little over 30K in parts and that includes a brand new crate motor, and I’m not finished with ordering parts, you would be surprised how the little things you need will add up quickly, good luck , if you have the budget for the swap and the ability to do it go for it, there truly is nothing like the feeling of a big block.
Old Oct 29, 2022 | 11:35 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
This is how you put BBC in a SBC frame
Old Oct 29, 2022 | 01:10 PM
911Kolsen's Avatar
911Kolsen
I don't think you could make mine look like it came from the factory!!
