My Winterizing Process
Old Nov 15, 2022 | 10:03 AM
iamq's Avatar
iamq
Default My Winterizing Process
This year I decided to document with pictures my winterizing process, maybe my kid will follow it when it gets passed to him....hahah
File Type: pdf
Old Nov 15, 2022 | 10:24 AM
fyreline's Avatar
fyreline
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
Very thorough and I'm sure the peace of mind it gives you is worth the small investment in time & effort. Guess I'm a minimalist. I drive the car, fill it with gas, put it in the garage, plug in the battery maintainer and cover it up. That's it. Been doing this for ten years or more with the 1962 for storage of about five months here in snowy, freezing Central New York while we are at our Florida home. My 2014 Premiere Edition C7 convertible sits right beside it, having undergone the same rigorous procedure, as have all my Corvettes before it. Both cars have always started right up and run fine in the spring. To each their own, whatever works for you is the right way to do it.
Old Nov 15, 2022 | 10:26 AM
65L78's Avatar
65L78
Hey iamq, read your pdf, thank you for the pointers! Will definitely do the same with my carburetor.
Hate to have to put protection on my vette as well hahaha
Old Nov 15, 2022 | 12:27 PM
iamq's Avatar
iamq
Always love the color of your 62.
Most of the process was put together when I had to put the car away for 30 years....came out the other side just fine...
Old Nov 16, 2022 | 11:15 AM
BAmacker's Avatar
BAmacker
Ditto here, a battery maintainer and that's it. No gas additives, premium fuel from the pump. Been doing it this way for almost 25 years, the carb works perfectly and hasn't been adjusted or touched in 22+ years. To each his own.
Old Nov 16, 2022 | 11:26 AM
gilbybarr's Avatar
gilbybarr
Many many threads on the suggested procedures. Mine now: battery maintainer & full gas tank (I live in Tennessee so no hard winters here and I can take the cars out for exercise when dry). In the old days in upstate NY (the great white north): Change oil/filter; Wash and dry car well & wax, drive around the block to drain water out of pockets; fill gas tank and add stabil; vacuum interior; increase air in tires by 5psi (adjust back in the spring); heavy poly on the floor under the entire car; windows up; moisture bag inside car sitting in a plastic or glass tray; cover car and let it sleep until spring.
Old Nov 16, 2022 | 11:31 AM
petdoc's Avatar
petdoc
My winterization procedure list:
1) Close floor vents if temps dip below 50 F*
2) Drive weekly
Old Nov 16, 2022 | 01:09 PM
boxster99t's Avatar
boxster99t
Old Nov 16, 2022 | 02:42 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
My vintage rolling stock resides in an unheated / uncooled barn year round. My winterization consists of hooking up a battery minder, if I can find one. Closing the barn door.
My suggestions: Don't over think this. These are just ol' Shev-a-lays. They'll be ready to serve you faithfully again in the spring.
Or maybe all winter long:
Old Nov 16, 2022 | 04:16 PM
2KREDVert's Avatar
2KREDVert
Don't do anything different here in San Diego for year round driving. Glad I don't have to do all that because I have too many collector cars.
Old Nov 16, 2022 | 04:44 PM
iamq's Avatar
iamq
Ok, you guys win.... guess it's hard to change old habits....
Just came in from the garage dealing with my 2 year old snowblower, probably didn't put Stabil in before I went south last year.... this is the Jell-O at the bottom of the float bowl... same stuff in a couple of other passages....fn ethanol...
Old Nov 16, 2022 | 04:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
to be fair I don't think any gas will last over two years
Old Nov 16, 2022 | 04:58 PM
iamq's Avatar
iamq
It sat for 10 months...
Old Nov 16, 2022 | 05:43 PM
BAmacker's Avatar
BAmacker
That's water in the fuel or bad fuel. Ethanol doesn't do that on its own.
Old Nov 16, 2022 | 11:02 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
One other step to consider is putting steel wool up the tail pipes if there is any chance of rodents making a winter home in the mufflers.
To My Winterizing Process
